Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - compressor moisture help
Old 03-07-2013, 07:36 PM
mitmaks's Avatar
mitmaks mitmaks is offline
Last journal entry: Grille
Specifications
Width 18.1"
CFM @ 100PSI 9
PSI Range 116-145
Control Panel Baseplate
Regulator Size 3/8"
Oil Level Sight Glass Oversized
Oil Level Indicator Sight Glass
Crankcase Breather Metal
Engine Throttle Control Pneumatic
Actual Weight 144 lbs
Length 42.1"
Height 24.4"
That is not large enough compressor to paint car, you might do a panel and that's about it. I have water trap after 50ft of hose and then another dissicant filter right at the gun.
