Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - compressor moisture help
Old 03-08-2013, 10:59 AM
swvalcon's Avatar
swvalcon swvalcon is offline
Last journal entry: rust on lt body shell
Part of your problem is all that rubber hose. Gives to many places for water to build up then come out in one big shot. Try to plum it into some steel or copper line. If you have and old drive shaft and are a good welder. Mount it up right, put a petcock in the bottom, put a fitting about half way up for air in,then a fitting at the top for air out. Put your water traps on the air out side. I like the water filter that takes a paper roll just before my hose to the gun.
