Compressor not restarting :( - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2009, 08:46 PM
I have a little issue.. well actually a big issue. My compressor stops after it reaches a certain pressure (135psi i think?) without a problem, however when it dips below lets say 90psi it never kicks in, so basically I can run the tank dry and the darn thing will never start up again.
Also, I push down the lever to the Auto On position but nothing happens. I have to manually push these little contact tabs (which lock into place after) to get it to kick in, once the compressor reaches 135psi they spring out (disconnect).
I hope I make somewhat sense?
Old 04-08-2009, 09:13 PM
302 Z28's Avatar
Had the same problem just yesterday on my compressor. The little spring loaded tabs on the pressure switch have to move freely in the off position. When in the off position you should be able to move the tabs around a bit. One of mine had become stuck and wasn't moving around freely and the lower contact on the tab was not making. Personally I think it's a design flaw with IR compressors. I am looking at replacing the switch with a different design.
FWIW do this with the cord unplugged
Vince
Old 04-08-2009, 09:22 PM
^ thanks
I checked and it doesn't seem to be the same issue as you experienced
Old 04-08-2009, 09:27 PM
302 Z28's Avatar
If you have a volt/ohm meter check for continuity when the switch is closed between the upper and lower wiring connections on one side of the switch. I still bet that one of those spring loaded tabs are not contacting the upper and lower contacts.
Vince
Old 04-08-2009, 09:52 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
It is definately the pressure switch. That's all it can be if you can push the contacts closed to get it to start. Replace the switch and it will solve your issue.
Old 04-08-2009, 10:10 PM
IR quality my butt.. this thing is about 1.5yrs old
Old 04-09-2009, 09:31 AM
Ok, so I called IR and they only provide 1yr warranty on the switch, 2yr on the motor.
That means I'll either cough up the money for an IR unit (#54441738) or get another brand. They quoted me $106.00+tx cdn, which is about $87+tx usd for a replacement.
Can anyone recommend a reliable switch in a relatively small form factor (preferably)
Old 04-09-2009, 09:54 AM
machinist & fabricator
i have the same compressor, and my pressure switch has crapped out on me several times.
Old 04-09-2009, 10:39 AM
^ did you ever replace the switch? if so, was it with the same IR part or another brand?
Old 04-09-2009, 12:22 PM
ericnova72's Avatar
More for Less Racer
Check your local industrial/electrical supply, it is a common switch. The same type is used on a well water pump, just with different pressure settings.
Old 04-09-2009, 12:32 PM
Which one of these would suit my application best? I found these at my local Princess Auto (harbour frieght equiv) #8050742? (see attached image)
The one in the link provided has a factory set psi on at 70 and an off setting at 100, I take i that one could adjust this for 135 or so? Or does cut-out range mean something else?
Wouldn't I need something with an adjustable ON/OFF PSI setting? As in I would need something to turn on at 90psi and stop at 135psi or so?
https://www.surpluscenter.com/item.a...36-DS&catname=
# Rated 1 1/2 HP at 115V
# Rated 2 HP at 230V
# Factory set PSI ON 70
# Factory set PSI OFF 100
# Adjust. Cut Out Range 70-150
# Size 3 3/4" x 3 5/8" x 2"
# Shpg 1-1/2 lb
Name:	pressure swtich.JPG
Old 04-09-2009, 12:46 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You can cross reference your switch to a Square D brand switch.
GRANGER has many listed.
Old 04-09-2009, 02:57 PM
302 Z28's Avatar
Did you ever check the continuity between the contactors to see which leg is not making contact? I would not be so quick to replace the switch, there isn't very much to them. They are easy to troubleshoot. That price IR gave you is ludicrous IMO.
Vince
Old 04-09-2009, 05:31 PM
ericnova72's Avatar
More for Less Racer
What you linked to is close, but has no ability to individually set the on and off points, they are fixed at 30 psi differential from each other. If you set the on at 90 the off would automatically be 120. You got the idea, though.
Old 04-09-2009, 06:27 PM
NO! It is not the same as a water pump switch because it has to have a provision for an unloader for the pump, besides it is dangerous to try to adjust that much pressure into a switch that is designed to operate at less than half what an air compressor uses. Without that unloader the motor will be damaged from excessive start-up torque. Use the right switch and don't try to "make" something work because you can damage your compressor and maybe yourself, NEVER try to use a water pump switch on a compressor!
Don't know if they deliver to where you live but these guys will have what you need at a decent price.
This one maybe?
http://www.surpluscenter.com/item.as...-1798&catname=
www.surpluscenter.com/pages/093.pdf
A heavier duty switch with different settings.
http://www.surpluscenter.com/item.as...6-LMV&catname=
Engine Not Restarting Canadian Charlie Engine 3 11-21-2007 11:04 AM
problems restarting engine (novice) dhomsey Hotrodding Basics 4 07-21-2006 01:34 PM
give me tips for restarting an engine thats been sitting... QuikSSilver Engine 5 12-05-2002 10:22 PM
