Compressor not Running - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2010, 08:25 AM
I have a Campbell Hausfeld compressor from Sears that was running fine and then I didnít use it for a few months. I went to use it about a month ago and it just would not run. Whenever I switch it on it sounds like the electric motor is straining and trying to run but it doesnít do anything except make the sound like its trying to turn. It does this for about 5 seconds and then the breaker cuts out. I know the circuit in our house is not a problem because we used the compressor for about 5 years on it. Does anyone know what I can do to fix this compressor?
Thanks
Old 07-28-2010, 08:34 AM
boatbob2
compressor help
Hi,when mine did that,i turned the pulley by hand,while i sprayed the motor with WD-40,i think it just needed a little lube,2 years later,it still runs fine.of course if your motor is wiped out,time for a new motor...stay away from harbor freight electric motors.
Old 07-28-2010, 08:49 AM
What Boatbob said but ANYTIME you have your hands near the pulleys or even have the guard removed TURN OFF THE BREAKER!!!!! Accidents DO happen and I personally know a guy with a crippled right hand because he tugged at the belts with the power on, sure enough it started!
Old 07-28-2010, 09:27 AM
Sounds like the start cap might have burned up.
1974 Pinto w/ 39k miles... won't stay running. ViperMonster800 Engine 32 04-20-2006 08:09 PM
400 Sbc running warm or not? 84KYSS Engine 16 11-16-2005 04:46 AM
ReAssembled Engine Making Noise Not Running Right HELP!!! 71gtx Engine 5 10-10-2005 04:59 PM
Running better with alternator disconnected? lluciano77 Electrical 8 02-08-2004 07:01 PM
Running Boards toolmansson Body - Exterior 3 05-08-2002 04:05 PM
