Compressor Oil
Went to buy some oil for my compressor and tried a few stores. No one has them, so at the last place I went to the salesman tried to sell me DIESEL engine oil. He said its the same thing,
Is he right? |
I can't say for Canada but stateside, I buy my compressor oil off the shelf at WalMart. Automative department, compressor section.
My compressor does have a pressure lubed system so I'll stick with the recommended stuff especially since it is easy to find around here. |
Eagle Model C5160V1
18.5 CFM @ 100 psi 220 volt - Upright tank with 3 cylinders Paid $599 How do I like it? No complaints. I can't run it out of air. Never had a problem with it. Been using it for about 5-6 years. During another forum discussion, some guy called me full of hot air. Said he couldn't find one for less than $1100. Whatever I said. I have a receipt for $599 and it wasn't a sale item. If you're interested in it and can't find a good price, drop me some email. I check on their current prices. I know the store will do drop shipments. |
Yah, use only non-detergent oil. I've been using detergent 30 Pennzoil in my 5 horse industrial 2 stage compressor for 21 years and I'm sure the detergent oil is just killing it. tom |
Just going with what I have done, and what I've been told by compressor manufacturers and dealers. They said non detergent oil was important, who am I to argue?
If the detergent oil is okay, maybe I'll give it a try next service.. It's cheaper (at least here) that the non. Last edited by sbchevfreak; 10-25-2004 at 10:58 PM. |
I got it from a friend of the family that moved from Michigan to Georgia. He uses a little chinese pancake air compressor. Did I get the good end of the deal or what?
An old refrigeration compressor! Well, clearly, that calls for refrigeration oil. To get it right, you'll need to know what kind of refrigerant it used to pump. Your local HVAC distributor can fix you right up at about $50 a gallon.
side note: the previous owner of my compressor said he burned up the original motor when he tried to run it when it was cold - below freezing. Based on just that, I'd go with the multi-vis. Last edited by julmer; 10-26-2004 at 11:07 PM. |
go to www.bobistheoilguy.com
Also, what is different between refridgeration oil and non-detergent motor oil? I am thinking of 20w-30, of course non-detergent. |
HEY, Chevelle, The smiley face was supposed to be a clue. That old pump will probably run with just about anything you pour in it. I'd guess 30wt non-detergent would be an excellent choice.
There are a number of different refrigeration oils and they are often that expensive. You almost have to be a chemist to get everything right in refrigeration systems. Us auto guys usually think about 2 different Freons, R12 and R-134a. There are actually about 20 for different kinds of systems. |
| Recent Garage - Tools posts with photos |
