Compressor plug into dryer outlet? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2005, 05:38 PM
I am planning on purchasing a compressor such as this one:
http://www.harborfreight.com/cpi/cta...emnumber=92504
From my understanding i can simply wire a dryer cord/connector onto it and plug it into the dryer outlet.
Is this a correct assessment? Anything i should look out for? I am in a rent house and cannot add any lines..
Old 04-27-2005, 06:14 PM
4 Jaw Chuck's Avatar
Dryer plugs are rated for 30 amps at 220V three phase, as long as your under that it will work fine. I use my dryer plug for my TIG welder and my electric 5000 watt heater.
I use natural gas for drying clothes.
— Han Solo
Old 04-27-2005, 06:24 PM
will single phase plug into 3 phase?
Old 04-27-2005, 08:44 PM
302 Z28's Avatar
Nope, you will have to install a single phase receptacle, or see if the compressor motor is capapable of being run on 220V if it is single phase..
Vince
Old 04-27-2005, 09:44 PM
bentwings's Avatar
bentwings
My dryer outlet is single phase 220. I think most new residential is single phase with the 4 prong plug. In my area you need a special permit for 3 phase and about 500 bucks. I also have 220 single ph in my garage which I paid extra for. It is 60 amp capable. I have my TIG welder (220 1 ph) plugged in as well. The dryer outlet might handle the compressor shown. I think my dryer is 30 amp.
So far I haven't tripped out the garage outlet with the TIG but I have a 4 #6 wire cord and a massive 50 amp plug. Cost me 75 bucks for the d.. plug alone.
For the compressor, If you just use it occasionally it might be ok, but usually the plugs are behind the dryer and you have to move the thing to get at it. With some trickery you could make up a double outlet cord. The inspector would hang you out to dry LOL if he sees it however. Make sure you use big enough wire. I would guess at least 3 #8 or better.
Old 04-29-2005, 08:07 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Chuck,
Please don't "dry your clothes" after eating tacos.........
Old 04-30-2005, 12:17 PM
Fast Orange's Avatar
Idon't think that the dryer recept. in your house or garage could be 3ph..
I've never heard of a 3ph. residential dryer. You need to verify if comp. is
single ph.. If it is 1 ph.,purchase a plug to match your recept. Your recept
may be 3 wire or 4 wire. Either type will work on 1ph. comp.. If 3 wire, connect wiring as per diagram with plug.If 4 wire,connect 2 hot wires and
the ground wire as in plug diagram and leave neutral terminal empty unless
comp. also needs neutral for a control circuit. If you aren,t comfortable
with your ability to install the plug, call an electrician- the piece of mind
in knowing it's safe and correct is worth more than what it willcost.
Good Luck
Old 05-01-2005, 09:31 AM
Thanks.. that is what i needed to know..
Old 05-01-2005, 09:25 PM
bentwings's Avatar
bentwings
If I remember right the 4th wire in these plugs goes to an "earth ground" At my house there is a rod about 1 in dia in the ground with a very heavy wire going in to the house and to the electrical box where it is attached to the frame. In turn this grounded through the 4th wire to what ever appliance is plugged in. The wire in the appliance goes to a major ground like the metal frame on my welder. The electrician told me not to worry about it as long as the 3 prong was hooked up as he had it. It is. Not being an electrican I can't verify the theory. I think Orange is correct. I tried to get a 3 ph so I could hook the lathe and mill up but it was quite expensive and required a use permit. I essentially would be required to aggree not to use the outlet for commercial use. Meantime the no-nothing homeowners got wind of it and really squawked because they though it would mess up the tv and sat reception. My reaction is that I don't do welding "favors" for the neighbors which p.o's them. haha tough crap as far as I'm concerned. What goes around comes around. I told one of them I only work on my streetrod and my diesel truck not on regular gas burning cars. I'm now on the neighbohood watch list.
bentwings
Old 05-10-2005, 07:36 AM
Their specs are screwy. Electric motors draw ~ 10 times the running current when starting up this is called "locked rotor amps". So if running current is 12.5 amps, start up current is about 125 amps, not 23 as listed. In addition, since when does an electric motor on a compressor run with no load???
It is a dangerous practice to run a plug on a circuit that it's not intended for such as putting a 30 amp drier plug on a 20 amp piece of equipment. This is a violation. You must use the correct plug for the circuit and not go over or under. I'm a licensed electrician by trade.
water neck outlet on 350sbc question 73chevyhelp Engine 8 10-15-2004 10:47 PM
your answer is in a hair dryer!! Steve-0321 Engine 3 09-22-2004 08:31 PM
208/220 Power Outlet nova69 Garage - Tools 1 09-09-2004 04:52 AM
Ford 400 Press Fit Hose Outlet ???? gohealthyhome Engine 4 07-09-2002 06:31 AM
