Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Compressor pressure?
  #17 (permalink)
Old 08-23-2005, 01:22 PM
oldred oldred is offline
I have never seen Eaton play that phony numbers game like so many of the cheap compressors do so I think you can expect what Eaton says it will do. In all probability the problem is in that "10 CFM" DA since those cheapie outfits DO play with the numbers! If you can get hold of a really good DA, make sure it is lubed properly and the air regulated to the proper setting and I think you will see an amazing difference but if it is a faulty compressor then rest assured Eaton will not let you down.
