Compressor recommendations - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2012, 08:13 AM
Hi everyone just wondering if I could get some input on a compressor upgrade for my garage.I have a 60 gal 3hp Ingersoll rand that only put out 11.3 cfm now that just want cut it when you try to run a DA or Air File.I think if I had a 18 to 20 cfm compressor I would be OK but I'm not sure.Please chime In with what everybody has.Also which brands are better.
Thanks
Old 01-29-2012, 09:35 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
Thanks
is that 11.3 scfm @ 90 psi ?
I have a 6.5 hp on a 60gal DeVilbiss 2 cylinder, single stage (125 psi)
its rated at 9.4 scfm @ 90 psi and 11.9 scfm @ 40 psi
if you are using good quality air tools, it seems to keep up OK
cheap tools use a lot more air volume
Eaton Compressor threatens to sue me over "Made in China" compressor post Jon Hotrodders' Lounge 190 03-06-2015 07:11 AM
Oil Pan Recommendations daveh Engine 0 04-09-2010 03:01 PM
454 Cam Recommendations crashtech Engine 5 05-17-2005 04:38 PM
Ingersoll Rand Compressor Recommendations daveh Garage - Tools 8 02-02-2005 03:38 PM
Cam recommendations 66truck4spd Engine 6 12-23-2003 07:56 AM
