Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Compressor Regulator, line size and pipe set up
Old 12-07-2012, 07:16 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
one will not lose pressure with a long line once you are hooked up you will see the same pressure everywhere in the system..the airout of the compressor is hot and needs to cool so the air/water seperator works as it only works on water that is liquid and not in the vapor form..I have a 100 feet of line between the compressor and my air/water seperator. I use one of the small dessicant inline filters after the filter regulator as a tattletale as they turn blue if any moisture is getting through..mine works fine on my plasma and for painting..
Sam
