Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Compressor Regulator, line size and pipe set up
Old 12-07-2012, 08:28 PM
timothale timothale is offline
Wiki Edits: 27
filter regulator.
I have a couple filter regulators. with air snap fittings that are portable. I don't run the air thru the filter reg when just using air for blowing chips when using the lathe, Mill or wood working equipment . I have a Harbor freight auto water drain plumbed with a T and manual drain todrain the compressor tank , My compressor is up in the air 8 ft high in a corner on a 4 X 4 Ft hanging from the roof, platform
