Compressor SCFM. When's enough? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2014, 06:37 PM
Wiki Edits: 31
I've had a custom gas powered compressor ( no 220v available ) project going for a while. I have a 20 gallon tank mounted onto a custom frame which can be towed with a garden tractor. I also have 2 7hp Harbor Freight engines, and 3hp twin cylinder pumps rated at 10 CFM each @ 90 PSI, so I can have 20 SCFM..
Now, procrastination has set in, but I'm probably going to media blast a friends 2 horse trailer for her this summer and then paint it, so I need it operational..
Looking thru my April flyers, the 11hp engine is $249 now but it would be enough to run the 5hp sized pump rated at 15.2 SCFM @90, and the pumps on sale too..
Now, I'm thinking I can stay with what I've got, for 20 CFM, buy another setup with the 11hp/5hp pump and run a single pump setup for 15.2 CFM, or I can go hog wild, and buy a new 11hp engine and 5hp pump, and mount one of my 7hp/ 3hp pumps for a total of 25 CFM @ 90 PSI..
I have a continuous run unloader valve and everything needed to make it safe.. Which direction should I go? Obviously a single engine will burn less gas.
Old 04-04-2014, 10:51 AM
S10xGN's Avatar
Gotta love a turbo!
I couldn't comfortably blast with my 7.5HP Northern 27 CFM unit. It took half an hour to do 1 sq foot, so I resorted to chemical and mechanical means...
Russ
Old 04-05-2014, 05:21 PM
Wiki Edits: 31
Well, just down low on her trailer really needs blasting.. Up top is reasonably clean and I'll probably just run the DA with some 36 grit.
I guess I could really blow my money and buy 2 11hp engines and 2 5hp pumps, to make 30 SCFM which is the max that my unloader valve is rated for, but that's $1k investment in all new equipment for 5 SCFM
Eaton Compressor threatens to sue me over "Made in China" compressor post Jon Hotrodders' Lounge 190 03-06-2015 07:11 AM
a/c compressor f/bird Hotrodding Basics 16 07-08-2013 08:12 PM
Anybody own or have info for a 5hp 18.5 80gallon blue Excel Compressor air compressor snapped finger Garage - Tools 0 03-25-2013 12:33 AM
Sand Blaster SCFM Jude-Racer Garage - Tools 4 04-13-2006 01:30 PM
A/C Compressor cfuller Electrical 4 05-07-2004 03:56 PM
