Compressor size for shooting and using a DA - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2012, 02:55 PM
Jimbo17's Avatar
Nostalgic Racing Decals
What size compressor and brand should I be looking for to shoot a car and run a DA without running out of air which is what my compressor is doing now.
I know this exact same question as been asked many times in the past but I could not find a thread relating to it.
Jimbo
Old 08-18-2012, 04:45 PM
my D.A uses alot of air, it uses about 14-15 cfm but its about a millions years old maybe newer one are more efficient. my big compressor is a 125 gallon 10hp gas powered unit and pushes about 35 cfm and runs everything with out trouble, my smaller ridgid 9 gallon which puts out like 8-9 cfm runs out of air fast with the DA. but i would think one of those stand up 70-80 gallon compressors that are like 5hp should be enough since most that ive seen push out like 14-20 cfm as far as brand you cant go wrong with any of the big names like IR or the unit from sears but honestly i know people with harbor freight specials that have run reliably for years
Old 08-18-2012, 05:52 PM
Mach1460's Avatar
Last journal entry: Project 92' Eddie
I have a sanborn 80 gallon single phase 14CFM@90 PSI--max PSI 155 and It runs a lot when I use my DA ( spent the last 2 weeks on and on sanding my bronco down to bare metal) I have a Chicago Pnumatic 6" da (cheapo) So it might use a lot more air than a good brand. When I break out the HVLP guns it barely runs. DAs suck a ton of air period.
Old 08-18-2012, 06:11 PM
I have a Dynabrade and my little 13 gallon 4 horse CH compressor will do better than keep up. (it actually pumps up and shuts off, while I'm using it) I also have a Chicago Pneumatic, and the lil' compressor won't even try to run it.
Not all DAs are created equal.
Old 08-18-2012, 07:02 PM
compressor size
When getting a compressor ,look for amount of cfm of air it will supply. And I would go no smaller than a 4 horse motor (220). Also the larger the tank,the more air you can store,so a larger tank will not cause compressor to come on as often. I had a hausfield/cambell 4 horse with 60 gallon tank. Served me well although I only used ONE tool at a time. Check cfm for each tool,rachet,da,spray gun and match compressor output (cfm) to the highest.
Old 08-18-2012, 07:49 PM
mitmaks's Avatar
Last journal entry: Grille
I have palm D/A sander and it runs great with my Kobalt compressor. However air die grinder will not run with it for more than 5 minutes, starts running out of air real fast.
Old 08-20-2012, 01:35 PM
Last journal entry: getting started
how about adding a tank
how about adding a tank to my existing IR 60 gallon tank? Does more tank space mean it will run less? or just take longer to catch up?
Old 08-20-2012, 03:25 PM
chevymike's Avatar
I recommend a dual stage compressor. They tend to have more CFM rating for a given HP rating. Also a 220VAC which will use less power for the same HP rating.
Old 08-22-2012, 08:16 AM
K72Nova's Avatar
I agree with chevymike, if you want a compressor that will stand up to air tools then go with a dual stage, that's what they're made for. I bought a Quincy, Model # 2V41C60VC and couldn't be happier. It's a bit pricey at around $1400 but it will live forever and is rebuildable. When I was looking into buying mine I had actually heard really good things about the HF 80 Gallon dual stage, if I remember right the motor was built in the US and is rebuildable.
Preferred gun tip size for shooting Metallic base coats. 67Elcamino Body - Exterior 1 03-23-2012 10:35 PM
air compressor size miamipops Garage - Tools 1 04-27-2010 07:17 AM
Compressor Tank Size Morgan22 Garage - Tools 24 01-31-2008 06:06 AM
What size tip for shooting jambs? cab Body - Exterior 1 01-15-2007 09:50 PM
What size Compressor? johnnymopar Garage - Tools 5 01-12-2004 03:53 PM
