Hey guys, I've been lurking around on this site for a few weeks as a guest picking up as much information as I can before painting my car but I have a few questions I decided to bring up here so I finally registered.
First, I own a Chrysler Cirrus (not exactly a hot rod...) and my buddy was driving a while back when it got hit. I've recently decided to do all the body work and painting myself. I don't have anywhere to paint this except for my aunt's garage and I know she wouldn't like it if I tried to wire it for 220v so i'm stuck with 110/120v. I've emailed a guy on craigslist with a Craftsman compressor model number 919 176290. On it, it says: 8.8 scfm @ 40 psi, 7.0 scfm@90 psi, and 125 max psi. He also stated that this was a 110/120 volt unit. Do these CFM ratings sound realistic? I've NEVER been able to find a compressor under 220v that could put out that much air. I tried doing some research on google according to that model number but there is absolutely nothing. It's like as if that compressor doesn't even exist.
I know the tank is a bit small but I think with a filter on the wall and a filter at the gun, i'll be safe from moisture problems from the compressor running regularly off the 15 gallon tank.
Now, I know that I'd be hard pressed to run a "real" gun off of that compressor which is why i've done a little more research and i've come up with a few options. First I looked on ebay for that W400 copy that you guys were raving about. However I came up short, well... not entirely. I found the R400 which seems very similar to what you guys were playing around with.
It claims to only draw 3-4CFM at 30-50 psi, which even if it draws double that, I should still be safe with the compressor, assuming the ratings weren't inflated.
The second option (which i'll probably end up getting anyway) is the Eastwood Concours gun. This was the only "name brand" low CFM gun that I could find anywhere. I even got a chance to email Kevin Tetz of Paintucation.com and Trucks! on SpikeTV to talk to him about the Concours gun since there's his review of it right on the Eastwood website. He confirmed that it really does only draw 4cfm@29psi. Just to triple check, I was wondeirng if any of you guys had any experience with these guns?
Thanks in advance for responding!
