Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - compressor storage
Old 12-26-2006, 11:22 AM
oldred oldred is offline
Just drain the water and then close the valve don't leave it open and don't drain the pressure from the tank, the pressure will probably bleed off anyway after a while but nothing is to be gained from completely discharging the tank. Discharging the pressure occasionally is not going to hurt anything but if you are doing it frequently over time it can actually lead to shorter tank service life.
