Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Compressor Tank Size
Old 01-20-2008, 04:47 PM
aminga's Avatar
aminga aminga is offline
Last journal entry: Cleaning and Powder coat
Originally Posted by Morgan22
Thanks Guys,
Actually I had seen the one from Harbor and they are out of stock when I called yesterday. I just used the link to show the Model I was thinking of.
I still owe you one Oldred, thanks.
Has anyone had one of these Puma compressors and what did you think of it?
I liked the separate cylinders, I thought they would tend to run cooler.
Morgan
Morgan,
I just hooked up a 7.5 HP PUMA in my garage. No word on durability. But it's a baldor industrial Motor. Cast iron pump (3 cylinder) And it appears to put out what they say 25 CFM) because it will keep up with my sand blaster running with the biggest nozzle in place.
The only downside is that tank pressure gauge wasn't reading right. I just haven't called them to get a replacement.
