compressor wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2010, 03:35 AM
compressor wiring
ok i want to get a bigger compressor 60 gal tank. lowes has one 110/220 the book says that you can wire this motor either way .if i wanted to use the 220 side couldnt i run a jumper wire off my dryer hookup and have a 220 outlet in my shop that way and use that. we dont use the dryer every hr and i dont paint or sand blast every hr my main breaker in my house box is 100amp so in order to hook this up to 220v and have another line is to have the outside meter replaced by the power company and the inside box replaced and the main breaker replaced sounds like a lot of $$$$$$$$ just for a little upgrade.. if its ok to hookup 110 i guess i can use it like that............. any comments
Old 04-08-2010, 12:35 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
You scared me when you mentioned jumper wire.
How far away is your power panel ( main breaker, fuse box) from the compressor?
Rich
Old 04-08-2010, 05:14 PM
T-bucket23's Avatar
Wiki Edits: 26
You need an electrician !!
Chet
Old 04-08-2010, 06:46 PM
Wiki Edits: 31
I wouldn't jumper a 220 line, even if it was within code.... best call the electrician and have a new 220 line run
Old 04-08-2010, 08:14 PM
i didnt mean jumper wire would i be able to hard wire the line into the dryer line using the right 220 volt line of course . my electric box in my home is 65 fit to my shop the dryer is in the rear of the house bout 15 ft from my shop
Old 04-08-2010, 09:11 PM
Wiki Edits: 27
220 v extension cord.
I don't think code will allow you to have the air compressor pigtailed into the dryer, Commercial electricians do a lot of calculations for run load. starting loads, percent usage when designing a system..I did the extension cord 50 years ago . unplug the elect stove. plug in the cord and use the welder. If you do that you need to get a heavy duty extension cord with the right size wire rated for exterior use. When we built the new shop my son who is and electrician said he was tired of the lights dimming when the welder and air compressor were runing at the same time in the old shop. He put in a new meter. 200 amp 42 circuit service, and 100 amp sub panel and seperate circuits to every machine. When we need to weld something at the sawmill I have about 500 ft of exterior construction 50 amp cord and the GFCI spider distribution boxes. You can read the directions with the compressor and wire it for 110 V, it won't have as much power but will work ok .. Most require a 20 amp outlet wired with 12 ga wire. If there is room in your elect panel you might be able to add a 220 breaker.and run a new circuit to your garage. the problem could be like my old shop. dryer on , microwave on. Hair dryer being used and the lights go din. low voltage is hard for electronic equipment.
Old 04-09-2010, 06:33 AM
Do you have a panel box in the garage or an attached garage with no panel box?
Moon
