Comp's L79 Nostalgia Cam ? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-06-2013, 09:20 PM
thinwhiteduke's Avatar
Living In The Past
Originally Posted by vinniekq2 View Post
pick a cam to fit your head flow and CR
wanna listen to my cam idle?
Got your link you sent of your 'baby idling' thanks for that , don't check my pm's that often. sounds soo cool!
What's your cam again? Like 250 @ 50 IIRC ? I know it's roller . what's your SRC?
Duke
  #17 (permalink)
Old 10-06-2013, 09:21 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by jokerZ71 View Post
The L79 ran 11:1 CR.I don't think I'd wanna try that with today's fuel w/o going with a good aluminum head.
The L79 may have been advertised as 11.0:1, but trust me, it was less than that in reality. Treat this cam choice just like any other, match the intake closing point to the static compression ratio, figure your DCR and go with it. Actually, if I were going to build it, I might use a solid flat tappet cam and use the solid tappets with the 0.012" oil holes. The first motor I ever heard lope with a solid lifter cam just blew me away. It was a brand new '56 Chevy that idled sounding like potato, potato, potato, potato and the solids ticking just mesmerized me. I was 14 at the time.....and ruined forever.
P.S. Most all the OEM's have used wide lobe separation angles in the everyday motors because grandma does not want the motor loping on her way to bingo.
  #18 (permalink)
Old 10-06-2013, 09:29 PM
Living In The Past
.....potato, potato, potato, potato... Ha, ha, ha,....good one Tech!
Mmmm, ......it IS mesmerising.
Duke
  #19 (permalink)
jokerZ71's Avatar
Wrench Turner
I used a 30/30 cam in a 283 with 2.02 heads, when I was in high school. I also converted to shoulderless screw in studs in metal shop and ported the heads on the milling machine.
I ruined 4 valve grinding stones when I did my own 3 angle grind in the mechanics shop.
this junk(was junk when I finished with machining) went into a 64 chevyII. actually went fairly well
his lil 283 would go.He wuz a character tho.He wanted wider tires on the rear but couldn't afford a set of air shocks,so,he jacked the rear up to extend the shocks,then cut pieces of pipe & slid the pipe over the shocks to keep it up in the air.Talk about a ruff ride.LOL.When the lil motor got wore,he kept 2 1 quart coke bottles of 90 wt gear oil tied between the grill & radiator.He would run around the corner,pour a qt in so nobody would see him.It ran a long time like that.
  #20 (permalink)
vinniekq2's Avatar
for a 327 in an old Impala this is what I would want:
10.2:1
AFR 195s (or equal)
750 double pumper on a good intake(most people like the performer RPM)
1 3/4 tube headers
111203-10 NA 269 269 237 237 .555 .555 110 106 .022 .022 1,2,5
2500-6500 Rough idle, Street Performance/mild Strip. Recommend 9.5:1 CR, 2500+ stall.
a cam like this
4.11 gears
3500 stall if auto
you could always slow the car down a little to run 14s
The Following User Says Thank You to vinniekq2 For This Useful Post:
jokerZ71 (10-06-2013)
  #21 (permalink)
Old 10-06-2013, 09:32 PM
vinniekq2's Avatar
my cam
Duke
its a secret grind from comp,,,lol
256/264@ .050
420 lobe lift with 1.6/1.5 shaft rockers
  #22 (permalink)
Old 10-06-2013, 09:36 PM
Living In The Past
10.2:1
AFR 195s (or equal)
1 3/4 tube headers
a cam like this
4.11 gears
3500 stall if auto
Vinnie, pardon my ignorance, but what do the numbers 1,2,5 represent at the end of the cam specs?
Duke
  #23 (permalink)
Old 10-06-2013, 09:37 PM
jokerZ71's Avatar
Wrench Turner
Better than 14's would work also !!! LOL. I'm planning on a 4 speed auto becuz I want good gearing to get this boat goin & still be able to take a date out on a road trip.
  #24 (permalink)
Old 10-06-2013, 09:42 PM
Living In The Past
256/264@ .050
It's a 406?? ..SBC?? I can't remember I think yours is a small block? Kindly refresh my memory so I don't have to go back through years of post, LOL
Duke
  #25 (permalink)
Old 10-06-2013, 09:45 PM
Living In The Past
Wow! Your 'dating' at 51 yo. Good for you man!!!
Duke
  #26 (permalink)
jokerZ71's Avatar
Wrench Turner
I noticed Comp tightened LSA up from 114 to 112.They gave it more lift as well,but,gave the intake higher lift.An article I read said this cam(the original 151 cam) in the L79 wouldn't idle with a stock convertor.If Grandma could drive a stick,she was good to go.
  #27 (permalink)
vinniekq2's Avatar
Joker,the car would fit right into "American Graffiti" and would scare most people just from the sound at 6500
Thinwhiteduke
119993
NA
Custom Grind Camshaft
Mechanical Roller Special Order Camshaft. 1,2,5
  #28 (permalink)
Old 10-06-2013, 09:49 PM
vinniekq2's Avatar
My engine in the silver Corvette is 434 cube/Dart 227 heads,10.75:1,Jere Stahl custom headers for road race 1 7/8 stepped to 2 inch primaries-3 inch collectors matched to 3 inch mandrel bent exhaust,no flanges on collectors,all joints are slip clamps
  #29 (permalink)
Old 10-06-2013, 09:55 PM
jokerZ71's Avatar
Wrench Turner
Duke
Yep.My X wouldn't act rite,so,I gave her to somone less fortunate & raised my 3 kids myself.They are grown now.I still have a 19 year old @ home,but,it's time to play again !!!
  #30 (permalink)
Old 10-06-2013, 09:59 PM
Living In The Past
So it's BBC, ?????? Just want to clarify, i know 427 SBC is attainable . Im in Australia , not 'super' conversant with cubic inch SBC/BBC combinations. Sounds like a very efficient exhaust system....I'm going with a big block,,,,let's know..
Duke
Mmm...227 heads? Maybe sbc??
Lunati Cam 00010LK vs Comp Cam CL12-242-2 hollingshedlr Engine 2 05-14-2009 07:47 AM
Thoughts - Comp Nostalgia Plus N+LS6 Cam dsolomon Engine 1 02-26-2008 01:39 PM
Anyone try Comp Cams Nostalgia Cams ? super_silent Engine 13 11-22-2007 04:01 PM
comp cam cam lube runn141 Engine 3 12-18-2006 09:37 AM
350 L79 cam & vortecs? VEGA 3503508.5 Engine 11 05-22-2006 08:11 PM
