Comp's L79 Nostalgia Cam ? - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 10-07-2013, 01:36 AM
thinwhiteduke's Avatar
Living In The Past
Originally Posted by Greg T View Post
But the ones over in Australia said potahto potahto potahto potahto...
How come everyone wants to pull the piss out of me all off sudden!
No worries, I got big shoulders! LOL
If you wanna get it right,.... It's petatah !
Duke
  #47 (permalink)
Old 10-07-2013, 04:06 AM
jokerZ71's Avatar
Wrench Turner
Duke
Don't let it get to ya Duke.I'm from the South,so,ppl poke @ me too.What's funny is tho,I went up North 1 time & I was the only 1 there that didn't have an accent !!! LOL.
  #48 (permalink)
Old 10-07-2013, 08:53 AM
jokerZ71's Avatar
Wrench Turner
I fully understand...well, maybe not fully, ...have fun!!
Duke
That guy I gave her to don't understand either.After 12 yrs,he's still mad @ me for givin her to him !!! LOL.
  #49 (permalink)
Old 10-07-2013, 09:21 AM
Banned
Everyone talks about matching your cam to your APPLICATION (not just compression, or heads, or any other singular item), but truth be told that I take notice every time I pull next to an LS1 Camaro or TA with a far too large cam for the application. Those guys are running 240+ duration on a car at a stop light- if your car ever comes up to a stop light that's far too much duration, BUT it sounds damn cool.
We all know how to properly chose a cam, but most of us still find some way of justifying going a little bigger, just because that sound (and smell) is just as much a part of hotrodding as going fast.
In my book there's not a damn thing wrong with choosing a cam for sound- AS LONG AS you realize you're leaving a lot of power and speed on the table.
  #50 (permalink)
Old 10-07-2013, 10:17 AM
vinniekq2's Avatar
240 is too much
please,show me the math where you can show me my cam is too big?
256/264@.050
227 dart heads,10.75:1,too big 950 carb,too big 1 7/8 stepped headers,only using 3.50 gears
  #51 (permalink)
Old 10-07-2013, 10:21 AM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by jokerZ71 View Post
Yep. My X wouldn't act rite, so I gave her to someone less fortunate
Same deal with me. Must be somethin' in the water.
  #52 (permalink)
Old 10-07-2013, 10:32 AM
vinniekq2's Avatar
My "X" was a house keeper. My future X has her own place. see my album and you can see even the imports have similar attitudes.
  #53 (permalink)
Banned
256/264@.050
the math would be
PB-OR=x
PB is your RPM of your power band
OR is your RPM of your operating range
the further x is from 0 the more you screwed the pooch.
  #54 (permalink)
Old 10-07-2013, 10:34 AM
Wiki Edits: 326
My future X
"future X". Too funny.
  #55 (permalink)
Old 10-07-2013, 10:38 AM
vinniekq2's Avatar
ok,break it down for me
the math would be
PB-OR=x
the cam is 108 square
.420 lift X 1.6/1.5
256/264@.050
the peak power is 6500 RPM,,(tested 6470)
PB 4-6800
It is tuned for 92 octane
  #56 (permalink)
Old 10-07-2013, 12:16 PM
Banned
.420 lift X 1.6/1.5
256/264@.050
PB 4-6800
and your operating range?
If its a street car with typical tires and a TH350 I'm guessing 2000-3500 rpm?
If its a track only car then you're coming in around 160mph (based on a 3.5 gear)?
I really don't know what you run, I do recall you having a very well built 427 sbc or something like that though.
  #57 (permalink)
Old 10-07-2013, 12:31 PM
vinniekq2's Avatar
its 434 cubic inch small block gen 1
I run a 6k chip when on the street
I can drive at 60 mph if 5th gear at 2000 rpm
it comes alive at 3500,the tires will break loose in second gear at 3500 rpm.
in first gear ,any rpm
heads flow 327 cfm,forgot to include that(tested)
tires are 27.5 tall
  #58 (permalink)
Old 10-07-2013, 05:14 PM
jokerZ71's Avatar
Wrench Turner
Kinda like F'bird88 says about 882 heads."Give em to somebody you don't like".
  #59 (permalink)
Old 10-07-2013, 09:29 PM
Last journal entry: New Rev wheels and BFG KDW II tires
I may just be dreaming,but,I'm dreaming EFI on this build.I have priced out individual components for the edelbrock Pro Flow XT.It looks doable & within a decent price if it works out like I have it planned.The manifold itself is only $400.I'll need a pcm for trans control anyway.This would also let me run a knock sensor.I think I canput the whole EFI together for $1100 to $1200 if I pick the rite injectors the 1st time.That'll give me an available 1000 cfm.
Were you looking at running a megasquirt system?
I've been thinking of doing the same thing but was looking more at the Stealth Ram that I think Holley makes now. Maybe that would be too tall for the hood though?
I found this place that does conversions to 4 barrel intakes. It's not really cheap compared to the Pro Flow or Stealth Ram but the thing I like is it would keep the standard layout like an older engine has. Plus they look pretty bad *** imo.
EFI Conversions
  #60 (permalink)
Old 10-08-2013, 04:00 AM
jokerZ71's Avatar
Wrench Turner
I've looked @ several for my truck previously including fabbing 1 like you mentioned.I'll use a GM 0411 controller,mostly becuz if I run an electronic 4 spd I'll need to control it as well.I also like the Ramjet,but,it is only for Vortec heads.A complete Pro Flo XT is over 3K,but,if you use the GM controller & piece it together,you'can do it for half that including tuning.Same for the Ramjet.The TB Pro Flo is a good system as well.They also have a set up as you describe that uses a Vic Jr intake(I think).I Love EFI.Initial tuning may be kinda hairy,but,once you get it dialed in,it's done.No more fiddling,or,making adjustments unless you make a major change.
Lunati Cam 00010LK vs Comp Cam CL12-242-2 hollingshedlr Engine 2 05-14-2009 06:47 AM
Thoughts - Comp Nostalgia Plus N+LS6 Cam dsolomon Engine 1 02-26-2008 12:39 PM
Anyone try Comp Cams Nostalgia Cams ? super_silent Engine 13 11-22-2007 03:01 PM
comp cam cam lube runn141 Engine 3 12-18-2006 08:37 AM
350 L79 cam & vortecs? VEGA 3503508.5 Engine 11 05-22-2006 07:11 PM
