Comp's L79 Nostalgia Cam ? - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 10-08-2013, 08:53 AM
jokerZ71's Avatar
Wrench Turner
The E'brock Pro Flo 2 will have more of an Old Skool look as well.
  #62 (permalink)
Old 10-08-2013, 09:16 AM
spinn's Avatar
Originally Posted by vinniekq2 View Post
please,show me the math where you can show me my cam is too big?
256/264@.050
227 dart heads,10.75:1,too big 950 carb,too big 1 7/8 stepped headers,only using 3.50 gears
I think most people who are not racing, and still spending big bucks on the drive train, are looking for smooth power like you might get in a Mercedes. Nobody should be thinking you cannot drive around with that cam. I have built similar engines and know what to expect from that. The inexperienced might question if something is wrong during first operation. That build is not going to sail at 19-21 " of vacuum. There will be vibration and sound problems, that is the nature of the beast. When I get contracted to do a " pimp my ride" for a local, they are expecting it to perform like a video game more or less. At certain power levels their are compromises to be made. It isn't a how much hotrod can you handle deal ,either. It is more what works well after you tried it all.
  #63 (permalink)
Old 10-08-2013, 10:55 AM
Banned
"Can" and "should" are two different things. Based on a 6000rpm chip he has about 20 degrees too much duration. Less duration would equate to a quicker car, better durability, and better mileage. But you'd lose those dyno queen numbers and sound. It comes down to wanting "show" or "go". Nothing wrong with show either, it's what inspires most of us.
  #64 (permalink)
Old 10-08-2013, 05:25 PM
BigEd36's Avatar
. Vinnie, pardon my ignorance, but what do the numbers 1,2,5 represent at the end of the cam specs?
Thinwhiteduke, I don't think this was ever answered. 1 is "Stock valve springs can not be used.". 2 is "requires thrust button.". 5 is "Requires upgraded distributor gear."
Vinnie's recommendations are usually for Howards Cams (with good reason). If you download the Howards catalog the numbers for the notes are on page 96.
Ed
The Following 2 Users Say Thank You to BigEd36 For This Useful Post:
techinspector1 (10-08-2013), thinwhiteduke (10-08-2013)
  #65 (permalink)
Old 10-08-2013, 06:17 PM
thinwhiteduke's Avatar
Living In The Past
Thanks Ed, na I didn't get a clear answer on that, I assumed from Vinies reply that it had something to do with the fact that it was a custom grind.
Thanks for clarifying that.
Duke
  #66 (permalink)
Old 10-08-2013, 06:44 PM
Last journal entry: New Rev wheels and BFG KDW II tires
Originally Posted by jokerZ71 View Post
I've looked @ several for my truck previously including fabbing 1 like you mentioned.I'll use a GM 0411 controller,mostly becuz if I run an electronic 4 spd I'll need to control it as well.I also like the Ramjet,but,it is only for Vortec heads.A complete Pro Flo XT is over 3K,but,if you use the GM controller & piece it together,you'can do it for half that including tuning.Same for the Ramjet.The TB Pro Flo is a good system as well.They also have a set up as you describe that uses a Vic Jr intake(I think).I Love EFI.Initial tuning may be kinda hairy,but,once you get it dialed in,it's done.No more fiddling,or,making adjustments unless you make a major change.
I looked at that fi Vic Jr. intake they have but the power curve starts at 3500 rpm. I had a standard Vic Jr. on a 350 Chevy with a small stall convertor and 4.10 gears. It was in a 55 Chevy stepside and moved out pretty well. I never felt that it was short on power down low so the 3500 they start the power curve at has me a little skeptical. Especially if it was running mpfi.
Megasquirt makes a controller for 4l60's and 4l80's too called the Megashift. The prices on all this stuff isn't really that bad. I'm sure using the stock stuff and reflashing it would work but think the Megasquirt stuff would be less of a hassle.
MegaShift - (c) 2004, 2012 Bowling and Grippo
Their newest MS3X system is self learning too if you set it up with a wide band 02. You load it with a curve that is close to your engine combo and then it tunes itself from there. Another thing I like about this system is that if you are running a mpfi manifold you can run it sequentially instead of batch mode like a stock system. It seems like you would get much better drive-ability and power.
http://www.diyautotune.com/catalog/index.php
I'm not trying to talk you out of using the stock computer but didn't know if you knew about the new stuff they had available. It's definitely not the cheapest but the features that are available make the system really tempting. There are multiple systems available so you kind of tailor it to your needs.
The MS3X also comes with built in bluetooth so you can run the software on a smart phone if you wanted to.
  #67 (permalink)
BigEd36's Avatar
Sorry, I meant to add that you can download the Howards Cams catalog as a PDF at this link: Howards Cams
  #68 (permalink)
Old 10-08-2013, 07:20 PM
jokerZ71's Avatar
Wrench Turner
Megasquirt Kits / Assembled Engine Management Systems, Wideband o2 Sensor Systems and tuning products - DIYAutoTune.com
I've seen the ads for the megasquirt,but,haven't looked into it very deep.I will ck it out tho.Sounds like a good deal.There are lots of options out there.I like the Fast EZ EFI as well.You would think with all the competition that prices would come down.LOL.
  #69 (permalink)
Old 10-11-2013, 05:35 PM
jokerZ71's Avatar
Wrench Turner
Well'my search continues.I called the owner of the 64 Impala to let him know what time to meet me tomorrow & he had sold the Impala about an hour before I called.I can't have NUTHIN !!!
Lunati Cam 00010LK vs Comp Cam CL12-242-2 hollingshedlr Engine 2 05-14-2009 07:47 AM
Thoughts - Comp Nostalgia Plus N+LS6 Cam dsolomon Engine 1 02-26-2008 01:39 PM
Anyone try Comp Cams Nostalgia Cams ? super_silent Engine 13 11-22-2007 04:01 PM
comp cam cam lube runn141 Engine 3 12-18-2006 09:37 AM
350 L79 cam & vortecs? VEGA 3503508.5 Engine 11 05-22-2006 08:11 PM
