-   -   Comp's L79 Nostalgia Cam ? (http://www.hotrodders.com/forum/comps-l79-nostalgia-cam-246361.html)
jokerZ71 10-06-2013 05:57 PM
Looking & planning a possible 327 build in the future & came across this cam.It is spose to be a modern version of the L79 camshaft.Original cam specs were DUR @ .050 =I 222/E 222. LSA/ICL= 114/??? Lift = .447/.447. Specs for the L79 Nostalgia cam = DUR @ .050=I 229/E 236. LSA/ICL = 112/108. Lift = .468/.462. Has anybody used this cam? Will it make good power,or,is it just for noise & show? I heard the idle on youtube.It sounded good @ idle,but,I didn't anything about the performance of it.
vinniekq2 10-06-2013 07:01 PM
pick a cam to fit your head flow and CR
wanna listen to my cam idle?
jokerZ71 10-06-2013 07:18 PM
I was just curious about this cam.I had been looking over the specs of the L79/327 & came across this one.I was just wondering if anyone had any experience with it.The L79 ran 11:1 CR.I don't think I'd wanna try that with today's fuel w/o going with a good aluminum head.
jokerZ71 10-06-2013 07:21 PM
I iistened to your's.It sounds good.It sounds powerful.
vinniekq2 10-06-2013 07:21 PM
Ifthose specs are perfect for your engine and the performance you want,then that is a great cam.
What do you have in the engine and what would you like the vehicle to do?
You know I and a few others will try to get you to use some kind of roller cam
vinniekq2 10-06-2013 07:31 PM
Richard/fbird88 or any others want to work on this cam choice?
Thanks joker,even at my mature age(not what the boss thinks) I really like the sound of a powerful engine with a good cam and exhaust.
jokerZ71 10-06-2013 07:39 PM
I'm still in the process of tryin to get the car @ this point.I haven't even fully decided on an engine yet.Always had a soft spot for 327's.Especially the L79.I've owned 1 that I put in a 66 Chevy truck.Still have the 461 heads to it.A wristpin ruined the block.The car is spose to have a 283 in it,but,I have suspicions that it may actually be a 327.I'm spose to go look @ it next Sat.
jokerZ71 10-06-2013 07:42 PM
When it comes down to it' I'm almost sure to go roller.
thinwhiteduke 10-06-2013 07:46 PM
How about this one.
12-673-4 - NOSTALGIA PLUS Mechanical Flat Tappet Camshafts
It would be more compatible to 11:1 SCR , than the hydraulic one ya mentioned.
I've wondered about the Nostalgia range also, almost / nearly got one myself
Duke
jokerZ71 10-06-2013 07:54 PM
Originally Posted by thinwhiteduke (Post 1816593)
How about this one.
Duke
I saw that 1 also Duke.That cam is Comp's modern version of the old 30/30 Duntov cam.Used I think in the 375 HP Vette engines.I have a freind that had the original version in a 283.It would shake the fenders on his Biscayne.LOL.
vinniekq2 10-06-2013 07:57 PM
Joker,how do you like the power delivery? wide power band with top end charge?
snotty hard hitting mid range ,a little rough around the edges with a rough idle?
flat torque curve,nice daily driver with a little enhancement over stock?
vinniekq2 10-06-2013 08:03 PM
I used a 30/30 cam in a 283 with 2.02 heads, when I was in high school. I also converted to shoulderless screw in studs in metal shop and ported the heads on the milling machine.
I ruined 4 valve grinding stones when I did my own 3 angle grind in the mechanics shop.
this junk(was junk when I finished with machining) went into a 64 chevyII. actually went fairly well
thinwhiteduke 10-06-2013 08:13 PM
Oh yeah, that cam in a 283 would be hectic LOL, be nice, I like mechanical cams. Don't care much for a hyd cam in a fun car ...!
Duke
jokerZ71 10-06-2013 08:16 PM
I like a somwhat flat torque curve.I've always liked low to mid range power.This will be goin in a 64 Impala.Approx 3700 lbs.
jokerZ71 10-06-2013 08:18 PM
I'm thinkin good street cruiser with a 14 second 1/4 mile,or,there abouts.
