Comp's L79 Nostalgia Cam ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2013, 05:57 PM
jokerZ71's Avatar
Wrench Turner
Looking & planning a possible 327 build in the future & came across this cam.It is spose to be a modern version of the L79 camshaft.Original cam specs were DUR @ .050 =I 222/E 222. LSA/ICL= 114/??? Lift = .447/.447. Specs for the L79 Nostalgia cam = DUR @ .050=I 229/E 236. LSA/ICL = 112/108. Lift = .468/.462. Has anybody used this cam? Will it make good power,or,is it just for noise & show? I heard the idle on youtube.It sounded good @ idle,but,I didn't anything about the performance of it.
Old 10-06-2013, 07:01 PM
vinniekq2's Avatar
pick a cam to fit your head flow and CR
wanna listen to my cam idle?
Old 10-06-2013, 07:18 PM
jokerZ71's Avatar
Wrench Turner
I was just curious about this cam.I had been looking over the specs of the L79/327 & came across this one.I was just wondering if anyone had any experience with it.The L79 ran 11:1 CR.I don't think I'd wanna try that with today's fuel w/o going with a good aluminum head.
Old 10-06-2013, 07:21 PM
jokerZ71's Avatar
Wrench Turner
I iistened to your's.It sounds good.It sounds powerful.
vinniekq2's Avatar
Ifthose specs are perfect for your engine and the performance you want,then that is a great cam.
What do you have in the engine and what would you like the vehicle to do?
You know I and a few others will try to get you to use some kind of roller cam
Old 10-06-2013, 07:31 PM
vinniekq2's Avatar
Richard/fbird88 or any others want to work on this cam choice?
Thanks joker,even at my mature age(not what the boss thinks) I really like the sound of a powerful engine with a good cam and exhaust.
Old 10-06-2013, 07:39 PM
jokerZ71's Avatar
Wrench Turner
I'm still in the process of tryin to get the car @ this point.I haven't even fully decided on an engine yet.Always had a soft spot for 327's.Especially the L79.I've owned 1 that I put in a 66 Chevy truck.Still have the 461 heads to it.A wristpin ruined the block.The car is spose to have a 283 in it,but,I have suspicions that it may actually be a 327.I'm spose to go look @ it next Sat.
Old 10-06-2013, 07:42 PM
jokerZ71's Avatar
Wrench Turner
When it comes down to it' I'm almost sure to go roller.
Old 10-06-2013, 07:46 PM
thinwhiteduke's Avatar
Living In The Past
How about this one.
12-673-4 - NOSTALGIA PLUS Mechanical Flat Tappet Camshafts
It would be more compatible to 11:1 SCR , than the hydraulic one ya mentioned.
I've wondered about the Nostalgia range also, almost / nearly got one myself
Duke
Old 10-06-2013, 07:54 PM
jokerZ71's Avatar
Wrench Turner
Originally Posted by thinwhiteduke View Post
How about this one.
Duke
I saw that 1 also Duke.That cam is Comp's modern version of the old 30/30 Duntov cam.Used I think in the 375 HP Vette engines.I have a freind that had the original version in a 283.It would shake the fenders on his Biscayne.LOL.
Old 10-06-2013, 07:57 PM
vinniekq2's Avatar
Joker,how do you like the power delivery? wide power band with top end charge?
snotty hard hitting mid range ,a little rough around the edges with a rough idle?
flat torque curve,nice daily driver with a little enhancement over stock?
Old 10-06-2013, 08:03 PM
vinniekq2's Avatar
I used a 30/30 cam in a 283 with 2.02 heads, when I was in high school. I also converted to shoulderless screw in studs in metal shop and ported the heads on the milling machine.
I ruined 4 valve grinding stones when I did my own 3 angle grind in the mechanics shop.
this junk(was junk when I finished with machining) went into a 64 chevyII. actually went fairly well
Old 10-06-2013, 08:13 PM
Living In The Past
Oh yeah, that cam in a 283 would be hectic LOL, be nice, I like mechanical cams. Don't care much for a hyd cam in a fun car ...!
Duke
Old 10-06-2013, 08:16 PM
jokerZ71's Avatar
Wrench Turner
I like a somwhat flat torque curve.I've always liked low to mid range power.This will be goin in a 64 Impala.Approx 3700 lbs.
Old 10-06-2013, 08:18 PM
jokerZ71's Avatar
Wrench Turner
I'm thinkin good street cruiser with a 14 second 1/4 mile,or,there abouts.
Lunati Cam 00010LK vs Comp Cam CL12-242-2 hollingshedlr Engine 2 05-14-2009 06:47 AM
Thoughts - Comp Nostalgia Plus N+LS6 Cam dsolomon Engine 1 02-26-2008 12:39 PM
Anyone try Comp Cams Nostalgia Cams ? super_silent Engine 13 11-22-2007 03:01 PM
comp cam cam lube runn141 Engine 3 12-18-2006 08:37 AM
350 L79 cam & vortecs? VEGA 3503508.5 Engine 11 05-22-2006 07:11 PM
