computer chip for 4.8 chevy v8 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2008, 08:27 AM
I have a 2001 chevy silverado with a
4.8 & automatic trans.Has anyone used any of
these computer chips & if so are they any good?
What are the advantages of these chips? Do they
do what they claim to do or not? If these chips
are good What ones are a good one to buy?
I am retired & dont have a whole lot of money
to spend right now.Any info would be a real
big help.Thank You. BOB
Old 12-22-2008, 10:18 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
The 4.8 uses flash memory, not a replacable chip. It requires a plug-in computer to reprogram it.
They are all expensive and all pretty much do the same thing; lean out the fuel curve, advance the timing, and firm up the shifts. The result is a few HP that you can't feel and a lighter wallet.
Usually you can find someone on the internet who can do the same thing for $75. www.pcmforless.com has an introductory price that is higher, but subsequent reprogrammings are $50. check them out and see if they'll do your 4.8L. I've used them 4 times and have been very happy with my LT1.
Old 12-23-2008, 05:23 AM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
yup , a custom tune is 100X's better than a hypercrap one size fits all programmer,no chips since 1994.
Old 12-23-2008, 08:29 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
true enough but the hypercrap allows the OWNER to tweak the settings and down load the original preferences of the stock config, if needed... custom 1 off , you are forever tied to the originator of the application, could be good thang but more then likely not a good thang, especially if they close the doors of Mr Tuner's shop, just cause you think you can does not mean you can ..
Old 12-23-2008, 08:58 AM
World Famous VF-14
LOL I have Known the owner of PCM4LESS for a long time, I highly doubt he's going anywhere and no hypercrap is gonna give you the same power that a custom tuner knows about.
Old 12-23-2008, 10:40 AM
curtis73's Avatar
Wiki Edits: 16
+1 for PCMforless and Bryan Herter. He got my buddy's OBD2 383 LT1 to pass CA emissions including plug-in testing. Its has fully ported AL heads that flow 300 cfm, a 222/230 cam, headers, 30# injectors, 11:1 compression, a 58mm TB, air pump deleted, and LT4 knock sensors. I've used him several times for my own LT1 that is mildly modified, but I was so impressed that he got my buddy's 383 to pass OBD2 that I'm duplicating that package for myself.
Try doing that with a hypercrap.
need help timing my 96 chevy vortec 305 V8 jw4413nv Engine 4 01-12-2008 10:49 PM
Reconditioning a small block 350 chevy v8 Butchardos Engine 1 03-24-2003 11:28 PM
4.8-5.3 chevy v8 blackhawk Engine 0 03-16-2003 06:03 PM
48 Chevy 1/2 ton V8 engine placement tomy2tone01 Engine 3 12-09-2002 02:59 PM
1991 chevy 4wd V6 swap to V8 Michael Breaux Engine 3 10-20-2002 03:48 PM
