Computer controlled HEI
Does anyone know if this can be used without a computer. It is not perminant just to test start an engine. If so a diagram or instructions would be greatly appreciated. It is an IN cap coil type. I am just trying to help a buddy get his project out of his garage
Thanks in advance Chet |
What exactly are you trying to do start a engine with the coil in cap type of Gm HEI?
If so all you have to do is run a hot lead to the positive side of the cap there are 5 positions 3 in the back 2 in the front it will be the one marked Batt R
"SlowRide66" "Illegitimis non carborundum" Don't let the bastards grind you down! Crankshaft Coalition Master List of Hotrodding Forums |
Thanks, I wasnt sure if i would work without the computer or not. he just wants to fire the engine to move it and it is the only dist he has available at this time.
Thanks for the speedy replys. |
| Computer controlled flat tappet camshaft (TBI) | pirata 4x4 | Engine | 6 | 04-02-2005 11:01 PM |
| computer controlled timing | propaniac | Engine | 7 | 06-10-2004 07:31 AM |
| Computer controlled tranny retro fit. Controll your shift points/line pressure. | lykan | Transmission - Rearend | 1 | 10-16-2003 10:27 PM |
| Computer controlled to standalone | Forsaken502 | Engine | 2 | 09-06-2003 12:18 PM |
| truck 700 R4 computer controlled?? | Ridr | Transmission - Rearend | 2 | 07-09-2003 04:53 PM |
