Computer controlled HEI engine with adjustable advance?
This site says it can be done.... Eliminate the factory ECM, wire it into this stand alone: G4 Storm : Cost effective engine management you can rely on. : EngineLogics.com
Timing can be adjusted in all GM ECMs, no reason to change to an aftermarket.
1 Attachment(s)
Depending on the ECM/PCM there are differant size resolutions. This would be a middle ground. Also this is for Open Throttle, there is also one for Closed Throttle.
In other words more then enough. http://www.hotrodders.com/forum/atta...1&d=1350264632 |
| All times are GMT -6. The time now is 12:00 PM. |
