Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Computer controlled quadrajet on an early 350
Old 08-05-2012, 09:02 AM
LATECH's Avatar
LATECH LATECH is offline
The CCC carb is the one in the picture.Part number 210 is the TPS , it provides the computer with feedback in regards to the throttle posistion.
Part number 225 is the mixture control solenoid. It wont control A/F ratio without a computer. If this is the carb you have, at best it will run pig rich, foul plugs and be a total PITA.
Get an older non CCC quadrajet.
Put that thing back on the shelf.
ID:	67206   Click image for larger version
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
4speed57 (08-05-2012)
