Computer controlled tranny retro fit. Controll your shift points/line pressure. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2003, 10:20 PM
Hey guys, The 4l60e tranmission is computer controlled most of you know that.
Well now you can drop em in any rig they will bolt to and still adjust the shift points line pressure etc.
Anyhow you can change everythign about how/when these guys shift, and now you can controll it without having the onboard computer that comse with it. You can even change line pressure.
Here's link to a kiot I found that allows you to retro fit it into any older hot rod. It's whieghs in with a hefty price tag, but this kind of customization on a tranission is worth iit in my opinoin
I learned a lot here just lurking about,reading all your post and gaining a wealth of knowledge for that I thank you all, hope at least one of you guys can use this.
Here's the link, check it out
Old 10-16-2003, 10:27 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
I would use this controller:
http://www.compushift.com/
It's been out for years. Good tech suppport
Very easy to work with, controls pressure and shift points as desired.
