Computer engine simulations - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2006, 12:18 PM
I dun learned sumthin
I was wondering what you guys think about computer programs like desktop dyno. I have been thinking about getting one of these programs but am not sure which to get. The two big ones seem to be desktop dyno and engine analyzer. Which would you guys recomend?
Old 04-20-2006, 02:19 PM
Because the nature of this question has more to do with ENGINE Horsepower.....I am moving this question to the Engine Forums section......where you should receive most and hopefully better informed answers.....
Deuce....Moderator....
Old 04-20-2006, 04:53 PM
We use EA Pro all the time. I have used Desktop dyno as well. EA Pro is a much better and more accurate program simply because it's much more sophiticated. That also makes it much more complicated to use correctly. You'll have to spend some time learning how to input all the data. It's also more expensive. The greatest value to EA is the amount of feedback data you get on an analysis. That feedback data provides a ton of direction on how to make the engine perform better.
If this is just a hobby and your not designing engines then DD 2000 is a better choice. It will get you close with off the shelf stuff you commonly find in catalogs.
Old 04-20-2006, 06:06 PM
I couldn't find any price info on EA. What does it cost reletivily to DD2000
Old 04-20-2006, 06:07 PM
Rick is right. EA Pro is very expensive when compared to DD. And very complex. It even permits the entry of specific geometry information related to the shape of the ports, I'm told.
Personally, I have both DD2000 and EA (not pro) plus. The plus is a set of accessory functions for EA (again, not pro). EA alone, I think is superior to DD. In fact, when I got my most recent computer, I don't think I even loaded DD on it. I may have, but I'm not using it at all. EA (again, not pro) permits inputs of a wide variety, including a lot of specific header information related to both primary and collector length and size. You are given a large database of parametric information, easily loaded by product name (i.e. Performer RPM intake) to set up the limits and characteristic variables that the program uses for the various engine components. You can add additional information if you like. For instance, if a "new" cylinder head becomes available, you can input its chamber size, general chamber shape, and actual flow bench numbers (up to 10, I think, per valve) creating a part file for the "new" head. You can also add a "new" hydraulic cam. BTW -- I think EA (again, not pro) has the full Comp catalog of cams for small block Chevys already built right into the program. And, you can download it free from their website to try it, then call Kevin with your credit card info, and he'll give you passcodes to make your sample copy into a full-up working copy. No delays. You can probably tell I like it. But, rest assured, I do not have any affiliation with them except as a customer. It's a cool product. DD is OK, but I really like EA. Check out http:www.performancetrends.com
109 or so, purchased direct.
Pat
Old 04-20-2006, 06:30 PM
If you have the money you may want to check out Dynomation.
Dynomation
Tmod
Old 04-20-2006, 07:00 PM
Yeah right! Im not going to put 400 dollars into a simulator. But thanks for the idea.
I did download a demo of EA and messed around with it for a while. Seems like a good program and may end up buying it.
Old 04-20-2006, 07:19 PM
OldSchoolChevy's Avatar
Gotta love the classics
well i hacked mine off of limewire, it works fine
Old 04-20-2006, 09:01 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
desktop dyno, never built an engine with info I used, too bad I can't build diesels on it! (diesels... )
it's fun to play around with, and have competitions with friends about engine building within certain parameters to see who can build the most powerful, or most torquey engine.
Old 04-21-2006, 09:20 AM
Thanks everybody I did download EA's demo and I like it so I will probably go that route. Thanks again.
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 04:05 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
Engine G-mac Engine 7 03-28-2006 10:21 AM
1969 350 375HP GM Goodwrench Replacement Engine Big Daddy Teez Engine 2 03-21-2006 07:36 AM
Self-Teaching Engine Computer Programs Mr.56Chevy Hotrodders' Lounge 6 01-12-2003 02:07 PM
