Computer problems with my 95 454 truck?? Won't completly start - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2011, 10:03 AM
Last journal entry: Albany Oregon Show
I have a problem with my 1995 1 ton dually 454. The computer is a obd 1. I changed the tbi and manifold to a edelbrock performer and a fast 4 barrel tbi. The company I bought the fast tbi changed my chip to work with the missing junk on the stock manifold and support the fast tbi. Almost all the wires that plugged into the various moduals now plug into the fast 4 barrel tbi. The only ones that didn't were for the gas tank evac system and the manifold heat riser module. I have tried to plug them in and just lay them on the manifold, but made no difference. The engine acts like it is going to start as long I have the starter engaged, but will not ever fully start. As soon as I let off the starter button it stalls. Once in a while it will chug a few rounds after I let off the starter but never fully starts. It does have power to the coil when the key is on. One time only it did do a 5 second rev after I dumped a quarter cup of gas in the tbi. I checked the fuel pressure at the tbi and it is at 38 lbs and I adjusted the pressure to 45 and no difference. It does have good blue spark and is in time. The company that sold me the equipment is helping but doesn't seem to be sure what the problem is. Before I return this thing to stock I will take the body to the junk yard and install the engine in a older body and get rid of the computer and all injection. This truck is worthless in its stock form. Any suggestions??
Bob
Old 12-06-2011, 08:02 PM
The mobile view is crap
Is the new chip a piggyback of the oem chip? If it is I would pull the new chip and try it with just the oem chip and see what happens. To get this thing to ever run right and get full potential from your setup your going to have to take it to a pro tuner and have a chip burned for it.
I would also post your question at www.thirdgen.org they do a lot with tbi over there.
Old 12-09-2011, 09:12 PM
chevykid90's Avatar
454, what turns your crank?
Last journal entry: Replacing bearings and crank
Maybe a long shot, but try replacing the spark plugs.. I didnt think it would ever happen but it seems like every time I change the fuel set up on any engine I have done (Ie: changing carbs out) all the spark plugs foul.. Not sure why it happens but like clockwork it never fails for me. Did it on my 305, changed out the quadrajet to an Edlebrock ran fine the first start up but when I tried to start it again it wouldnt, fouled them all up. Did the same thing with my 454, did a carb rebuild. Put the new one on, started fine the first time. Then again on the second start up it wouldnt run. Changed out the spark plugs and it fired right up. Also I had a 92 Jeep Cherokee, did a throttle body swap and again... fouled all the spark plugs. But now that I am typing this and I am thinking about it, is there something I was doing wrong?? That just doesnt seem normal at all....Now I am really starting to think about it...
Old 12-10-2011, 12:56 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
I am going to bet my money on the distributor not being installed correctly.
( timing too slow.)
more computer problems ChevelleSS_LS6 Off-Topic 0 10-13-2005 12:58 PM
computer problems APACHEMAN Electrical 7 12-02-2004 04:24 AM
Computer problems Yub350 Electrical 2 10-19-2004 04:06 PM
96 grand am computer problems gbowtie055 Electrical 4 09-09-2003 08:39 PM
Smoked computer during start Chadman Engine 3 08-20-2003 12:12 PM
