Computer Ram upgrade problem
Here I am, my humble computer and I...
Compaq Presario sr1200nx-purchased new a year ago 2.0GHz AMD Sempron processor NVIDIA GeForce MX4000 video card- overclocked a little and has its own cooling fan. Upgraded from 256mb DDR ram @ 333MHz to 512 * Motherboard: ASUS 7V8X-LA * Chipset: VIA KM400A .......................................... So, I want more speed out of it, and I purchased some 2x 256 Kingsron RAM that operates @ 400MHz. I installed it and when I fired my computer up it said it's still running at 333MHz, and I am wondering if anyone out there who has more skills with the compy than I do knows how to fix it so the memory (ram) runs at the rated 400MHz. Thanks guys, Matt link to moboard stats http://h10025.www1.hp.com/ewfrf/wc/...00069442#N10013 |
Buss speed
Doc here,
The link didn't work... However, I do not believe you Can exceed the Buss speed 333 mhz with just a ram upgrade, You SHOULD have to upgrade the buss to 400 Mhz ..which will mean more than Memory upgrades.. Refer to your Manual for max Buss speed and what it requires to get there, (like a new clock chip, maybe a new MPU, and interface chipsets..) But just putting a faster RAM won't get you there..It operates between a certain "Window of speed " depending on the buss, and if too low or too high, will just beep 7 times when you turn it on (MPU Failure) and give you nothing else, no boot..nothing..until you get the right speed RAM back in there.. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Hippie and Doc
![]() I rebooted the compy and I went into the BIOS, and under advanced settings found this: Local Bus IDE Adapter a) Diss___ (I forgot the rest of the word, it might be disengage) b) Primary c) Secondary d) Both (default setting) So I set it to A, and it had boot errors, and D is likely the same as B and C, only combined so I didn't try those options. I couldn't find a speed setting option. AAGH! This time the link should work for MoBoard Specs |
That is a proprietary Comapq Presario board made by Asus. I rebooted mine and went into BIOS and didn't see anything close to what yours had so Compaq may have their own BIOS version. You may want to contact Compaq support ( I have my own name for it but we won't go there. ) by what I see you should be able to run it at 400MHz.
Well, here it is, the deciding moment... am I an average Matt (my name's not Joe) or am I a Hotrodder?
a) sell the fast memory and call it a loss b) time for a speedhappy MoBoard. I'm seriously considering B- the thing I don't know is how much will the improved RAM speed from 333 to 400MHz help? The current MoBoard is good for AMD Sempron 3200+ processors (mine's a 2800), so maybe a new processor would be a better buy. |
I got a reply from the friendly people at Compaq, much different from the cut-n-paste hackjob emails from auto companies these days (which sucks, it'd be different if I were at the top of GM).
Thank you for contacting HP Total Care. I see that the Presario displays RAM speed as only 333MHz instead of the installed 400MHz. I will certainly help you with this. The Presairo is installed with Via KM400A chipset motherboard. This motherboard will support 266/333/400 MHz DDR DIMMS. If you install combination two speed, it will display and work at the rate of the slow speed RAM installed in it. The system may display the old speed and does not detect and display the high speed RAM, if the BIOS is not refreshed. Your idea of resetting the BIOS settings is correct. The system will detect the complete specifications of the RAM, only if the BIOS settings is refreshed. So, please reset the BIOS settings. This should resolve the issue. Use the following steps to reset the computer to its default BIOS settings: 1. Press the Power button to start the computer. 2. When the red Compaq logo is displayed on the monitor, press the F10 key on the keyboard. 3. Using the Arrow keys on the keyboard, select English as the desired language. Then press Enter to continue. 4. Select "Set Defaults and Exit." |
Well at least they replied, I'm guessing that wasn't real helpful.
right now it's a 2.0gig (2800 series) sempron, and I can run up to a 3200 series sempron.
Lo and Behold last night I was messin with the compy and I learned that the processor is rated at 2.0gig/333mhz. and the moboard can take 400mhz ram. so, it's in the processor. ugh, confusing. kinda like women. (see my title by the avatar) |
A lot of computers need to have the same speed ram or it will only read the ram of the slowest speed
also some motherboards the ram has to be in a certain order, like the larger stick in bank 1 the next in bank 2 etc... |
they're both 256mb, both 400mhz. the old ones were the same, except 333mhz.
and at www.tigerdirect.com they have a really good deal going on involving 512mb sticks or ram, 400mhz. I might buy those and sell what I have. |
A computer is only as fast as it's slowest component.
Remember that. With that being said everything has to be the same fast speed in order to get it. Your Compaq has a Sempron 2800+ (the replacement for a Duron) which is basically a slower Athlon XP, a budget chip. Athlon XP is to Pentium 4 as Sempron is to Celeron. Your Sempron runs on a 333Mhz Front Side Bus (FSB) motherboard with PC2700 (333Mhz) to match CPU. You purchased PC3200 (400Mhz) to try to upgrade your computer. If you are correct, then your motherboard can handle 400Mhz (most made in the last 2 years can) and your err was not realizing that you would have to upgrade the CPU in order to gain any speed. If you want to really upgrade, look up or contact Compaq to see if you can put an Athlon XP 3000+ or higher into your computer to make it close to twice as fast as your Sempron! 333Mhz CPU, 333Mhz RAM, 333Mhz Mobo: it's all good 400Mhz CPU, 400Mhz RAM, 400Mhz Mobo: it's all good 333Mhz CPU, 400Mhz RAM, 333Mhz Mobo: the RAM is only going to run at 333Mhz Right now your PC3200 (400Mhz) is only running as fast as your old RAM, you just have twice as much. And with how big programs are nowadays you are going to see quite a difference with 512Meg. ***Car analogy*** You have a 2.8L (Sempron CPU) 1985 Camaro(your mobo which is a good platform). You want to make it faster so you add a Garrett T10 Turbocharger (your 400Mhz RAM). It's not going to do any good since everything is out of balance. Understand what I'm saying? Now you drop in an LS1 (Athlon XP 3200+) and you are tearing up the streets with a balanced car! A good info site is http://www.driverheaven.net/ A lot of very nice folks on the forums there. Good online stores that I use alot are www.newegg.com (2 DVD burners on the way from them) and www.zipzoomfly.com ***Over-Inflated Ego warning*** If you have any more questions, I can give ya some good advise. I've pretty much always built my own computers. (My first comp was a second hand that someone else built.) The Pre-fab big box store computers (Dell included) tend to hack me off with cheap components and a bunch of Bull shoved down peoples throats. My newest comp works like a charm, and my old one is now my G/F's comp. My computer's specs: 64Bit Pentium 4 3.2Ghz, 1Gig DDR400 (dual channel), 2x120 Gig Hard drives, ATI X800XL Running Windows 64bit in a custom built from scratch water cooled silent case...and I love it! G/F's comp(my old gaming rig for about 2 years): Athlon XP2600+, 512Megs DDR333, ATI 9800 overclocked, silent watercool case mod |
I just jumped from 512 to a gig and really noticed the difference. I do a lot of 3D gaming, so its worth it. A video card would be a good investment too, if you are doing anything video-intensive.
K |
My first computer had 8MB ram, that was a fast machine.
My Moboard will take a AMD 3200 processor...
I run an overclockedd Nvidia Geforce MX4000... here's specs stock: core~275 memory~400 oc'd: core~360 memory~454 <fastest I can do it while maintaining system stability. I also added the processor fan from my old computer to keep it cool. good compy stuff store link... www.tigerdirect.com www.alienware.com <coolest pre-made computers ever! Friggin expensive though. Last edited by ChevelleSS_LS6; 10-18-2005 at 12:02 AM. |
| Engine stalling problem | JamesRS | Engine | 3 | 01-30-2006 11:22 AM |
| Ignition Problem | malibuman66 | Electrical | 17 | 01-24-2006 01:05 AM |
| Cross fire injector problem.. Help me... | zerozamora | Engine | 3 | 10-29-2002 01:23 PM |
| Fuel / Carb problem | DoubleVision | Engine | 5 | 10-28-2002 05:18 PM |
| Ignition problem??? | Centerline | Engine | 2 | 06-29-2002 05:53 AM |
