cone type mopar sure grip - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2013, 03:09 PM
been a while since i dismantled it which way do do the spring plates go? with the tabs going down on same side or opposite sides.
Old 06-21-2013, 04:07 PM
big gear head's Avatar
High Performance Rear Ends
Pic please. I can't remember what they look like.
Old 06-22-2013, 11:01 AM
big gear head att. is pic thanks
Name:	mopar cone sure grip.jpg
Old 06-22-2013, 02:40 PM
junior stocker's Avatar
The "notch" for the cross pin should tell you which way they go in. Butch/junior stocker.
Old 06-22-2013, 02:56 PM
The one that you have in is correct. Line up those 2 little tabs. I think the go beside each other. It's been years since I had one of those apart.
Old 07-05-2013, 05:11 AM
cranky1's Avatar
Just stuck
If you still haven't put this together yet, install the plates with the tabs on the same side in the small notch. The 'window' should never have anything in it.
Leather cone clutches namyzzo Transmission - Rearend 3 08-17-2012 07:05 AM
nose cone busted off of starter yragat Engine 7 10-17-2011 02:26 PM
Cracked nose cone on starter? 805puffer Engine 9 10-05-2008 06:11 PM
Anyone know about leather cone clutches? low budget rodder Transmission - Rearend 10 08-23-2008 09:16 PM
how to repair cone shaped lights. daoldbuick Body - Exterior 4 08-21-2008 08:17 AM
