Confirming rearend ratio - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2006, 07:06 PM
3100 Special's Avatar
Street Rod Dreamin'
Last journal entry: Last post project for a while
Reading through posts, I've gathered that you can count the crown teeth and divide by the pinion teeth to get the ratio.
Meaning... 39 crown and 13 pinion, I'll have a gear ratio of...3.0
Is this correct?
Old 01-07-2006, 10:27 PM
Correct.........
Like....... 41 divided by 10 = 4.10
Old 01-08-2006, 02:33 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Most ring gears also have the numbers stamped for you. Mine say 41/10. With the cover off I just rotate the ring until I see it stamped on there.
Old 01-08-2006, 03:11 PM
Street Rod Dreamin'
Thanks guys!
Rearend ratio/ rpms novatech Transmission - Rearend 5 12-19-2003 08:08 AM
dodge rearend ratio nick1947 Transmission - Rearend 0 03-20-2003 11:10 PM
what's the best rearend ratio for my truck? chevyman355 Transmission - Rearend 1 01-29-2003 08:02 PM
How do you tell rearend Ratio Bluegrass Transmission - Rearend 14 12-26-2002 01:56 PM
Gear Ratio ID on 9" Ford Rearend junkerette Transmission - Rearend 3 08-25-2002 04:19 AM
