Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Confused
Thread: Confused
Old 09-08-2003, 08:11 PM
jrhoss's Avatar
jrhoss jrhoss is offline
hows it going, some suggestions for your 400. go with a flatop 4 valve relief piston, idealy a hypereutectic. durable at a good cost the cylinder heads should be 76 ish chambers older style 920's 336's etc. try to stay in that range smaller chambers will put more heat into an already warm running engine. edelbrock performer rpm intakes work well from1800 to 55-5800 rpm right where that motor wants to be. lastly a 600 holley will work well but if you have limited tuning skills a 600 edelbrock is good for no hassle driveability. ps dont worry about the steamholes just buy the black fel pro gasket
