Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Confused
Thread: Confused
Old 09-09-2003, 10:35 PM
Forsaken502 Forsaken502 is offline
going back to the earlier 1.6 ratio question:
the 1.6 ratio effectively fools the engine into thinking that the cam has more lift because it opens the valve 1.6 times as much instead of 1.5. Make sure you get a set of springs that will be able to compress to this added lift.
