Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Confused about carbs, need help!
Old 01-16-2013, 11:17 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
Originally Posted by cobalt327 View Post
3000 stall speed and 3.08 = a big disappointment. The stall you can get by with but the rear gear will make the acceleration poor.
3.08 gear ratio is not a good gear for launching,true. From 25 MPH up,whats the difference from the 3.08 guy accellerating in low gear and the 3.73 guy accelerating in second gear?
At 60 MPH,in my car,using a 950 double pumper,I can yard the secondaries wfo with out bog or hesitation.In fifth gear my over all gear ratio is 2.87.
I have 5 gears so it makes more sense to go down a gear and use 1/2 throttle.
just saying,if the carb works,it should work at all RPMs
