-   -   confused on cam choice (http://www.hotrodders.com/forum/confused-cam-choice-83311.html)
75sprintguy 03-04-2006 11:08 PM
let me start with my set up its a chevy 307 holley 600 carb,holley dominator dual plane intake,every thing else stock.it has 411 gears out back 350 th tranny.im looking for a cam that wont kill my torque.i dont no jack about cams :confused: thanks very much
curtis73 03-05-2006 03:26 AM
in all honesty, don't change it. You have heads that won't allow your engine to rev past about 4000, and a relatively small bore that limits breathing. The intake and carb weren't what was holding you back. The new parts might have given you 15 hp, but you have to change those heads.
Engine power is based on a matching of all parameters: carb tuning, intake flow, head flow, compression, cam events, and exhaust. Simply changing to a performance cam, carb, and intake will mean you have a carb, intake, and cam tuned for higher performance, but heads, compression, and exhaust tuned for stock perfrormance. The net result will be a mismatch. Not only will you not gain any performance in the higher RPM range, you'll lose performance in the low-rpm range. Your performance will suffer big time.
I won't get into the finer points here, but all performance parts need to be matched together. You're starting with a small-bore engine, so you have to be extra careful with your choices.
