confused, distributor identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2013, 06:06 PM
I've been working on 27 T bucket, I've found out motor is 1975 350 block with 1964 to 1966 327 camal hump heads we think it has slight cam now it has hei but distributor cap looks like points with a adjustment window. it has seperate coil and a rotor inside now ive personally never seen this,if you google hei cap it does show the same on older models. im having alittle trouble setting timing has anyone ever come across this.
Old 04-29-2013, 06:30 PM
BOBCRMAN@aol.com's Avatar
Probably an electronic ign conversion on a points dist. Check out Pertronics, Accel, Mallory. etc.
How do you remove the distributor gear on an HEI distributor? against all odds Hotrodding Basics 4 01-31-2012 09:58 PM
Distributor has a tube running along side of the distributor? sscardino Hotrodding Basics 17 01-18-2012 07:25 PM
Confused over setting up my MSD distributor Irelands child Electrical 23 06-24-2011 06:09 PM
OK, now I'm more confused than before. 58Chev Electrical 4 03-18-2006 02:58 AM
Chevy points distributor identification abe Engine 2 07-30-2004 01:03 AM
