This confused the hell out of me, a little help please. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-18-2004, 06:09 AM
79 camaro 454's Avatar
when i put a cam in my pnontiac 400 my power brakes didnt work so i called up summit and got a resevoir thingy and now there like new in the future im gonna invest in a electric vacume pump...just sharing that with you all cheers.
  #17 (permalink)
Old 05-18-2004, 06:20 AM
Wiki Edits: 49
Re: dist
Originally posted by k-star
The dots on the chain have many people messed up!!!! It really does not matter iF you assemble the motor with the dots at 6:00/12:00 Or 12:00/12:00.
This is very true however, most engine builders and reference books recommend assembly with the crank at 12 o'clock and the cam at 6 o'clock simply because it makes it harder to screw it up.
Originally posted by k-star .......I tell all my customers to remove the valve cover rotate the motor untill you see the # 1 intake open then close continue untill the balancer is at tdc and install the distributor at # 1. When doing this they have never called back with a distributor out 180 deg..... It's a little more work but for the less skilled it works every time.
Like I said before, "If you're distributor rotor is pointing towards the firewall when you're engine is at top dead center on the compression stroke on #1 cylinder then you need to pull the distributor out and rotate it 180*."
Centerline
  #18 (permalink)
Old 05-18-2004, 10:38 AM
chianesi's Avatar
Never Give Up
In regards to the manifold vacuum, the more groos lift on the cam the less manifold pressure you will have and to correct it you might need a seperate vacuum tank
  #19 (permalink)
Old 05-18-2004, 11:40 AM
Bad Rat 414's Avatar
www.bigblock67chevelle.co m
I called Comp Cams and talked to them. They said I should have around 10" of vacuum. I also called Edelbrock and asked about the timing mark on the cam gear of their gear drive. It's not in the best place it looks like it's between the teeth. So I moved it to the next tooth. I'm waiting on the silicone to dry and I'll get back on it and fire it up and see what happens. Oh by the way, Edelbrock support was no help at all. The guy just told me "they're all that way".
  #20 (permalink)
Old 05-18-2004, 11:50 AM
Wrencher's Avatar
I hope it was fun, cause, it's gonna run the same, follow the above posts and you will be fine!!You will get 56 degrees of advance with the vac advance plugged in, set the timing w/out it!
  #21 (permalink)
Old 05-18-2004, 12:50 PM
I'm hoping this will fix my less than 5" of vacuum.
