This confused the hell out of me, a little help please. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2004, 02:51 PM
Bad Rat 414's Avatar
www.bigblock67chevelle.co m
My engine is a big block chevy and the cam is a Comp Cam 286H. With the vacuum advance disconnected the timeing is set at 12*. When I connect it it goes to 15* with manifold vacuum at the carb. on the vacuum advance unit. When I advance the throttle the timeing mark doesn't stop moving to around 56*.
I just did a vacuum check on the engine. I've got less than 5" of vacuum, which the guage says "late valve timing or leak at intake maifold".
I pulled the timing cover and check it out. The marks line up at 6:00 on the cam and 12:00 on the crank. BUT the distributor is 180* off. I've never seen an engine run with the distributor 180* out. It's time to start banging my head against the wall. Has anyone else ever heard of that. I didn't think it was possible.
Old 05-17-2004, 03:03 PM
Please remember that the cam only rotates once per 2 times of the crank.
Old 05-17-2004, 03:07 PM
poncho62's Avatar
Wiki Edits: 5
How does it run at those settings?
87442 is right about the timing marks on the cam. Turn the crank 1 revolution and everything will line up fine...........
Old 05-17-2004, 03:31 PM
That's true, but remember what I said. The cam gear mark is at 6:00 and the crank is at 12:00. That is the correct position, but the rotor button is 180* off (pointing towards the firewall).
Old 05-17-2004, 04:02 PM
At actual top-dead center, both the crank and cam dots will point to 12:00. Your distributor and cam alignment are fine.
Old 05-17-2004, 04:04 PM
Sorry that's not true.
Old 05-17-2004, 05:04 PM
Wiki Edits: 49
This is incorrect for a Chevy. The cam timing mark should be at 6 o'clock and the crank timing mark should be at 12 o'clock. If you're distributor rotor is pointing towards the firewall when you're at top dead center on the compression stroke on #1 cylinder then you need to pull the distributor out and rotate the rotor 180* and reinstall it.
Centerline
Old 05-17-2004, 05:20 PM
I totaly agree, but how did it run like this?????
Old 05-17-2004, 05:29 PM
Wiki Edits: 49
If you have the plug wires set 180 out as well it will run but not all that well.
Centerline
Old 05-17-2004, 05:41 PM
I didn't!!!!
Old 05-17-2004, 05:56 PM
Centerline
Nooo...
The crank is really at TDC twice(4 stroke) per cam rotation. The distributor is fine.
If the distributor were 180 deg than the plugs would be firing on the exhaust stroke, this would make it impossible for the engine to run.
Old 05-17-2004, 07:07 PM
Jmark's Avatar
Ok, here goes the story as told my hundreds of first time chevy engine builders across the country.
"I don't know why it won't run!!!! Piece of Junk!!! I set the cam gear at 6 and the crank gear at 12. I oil primed the engine, dropped in the dist with the rotor pointing just like it was on the old cap. Dropped on the cap, old wires still there, tried to start it and it blew flames out the carb and almost blew both mufflers off!!! Piece of junk!!! So now I pull number 1 plug and crank it until number 1 pushes my finger out of the spark plug hole and then line up the timing marks on the balancer and pointer and then pull the cap. Hey!! Its pointing to the firewall, not to number 1 like its supposed to!!! Piece of junk jumped timing!!!" or "My gears are stamped wrong!"....or.... "My dist gear spun!".....
So now you decide to pull the dist and set the rotor to point to number one and give it one more chance before you have it towed to the shop to have it fixed. Guess what??? Its starts and runs fine now. Why did it do this you ask??? Well, you're just so happy its running that you blow it off, throw on the hood and go for a spin.
When you install the gears as per the book, with the dots facing each other, the engine is set up at TOP DEAD EXHAUST on #1. You then need to rotate the engine one turn before installing the dist. You ask "Why is it like this?"....... I don't know! But its true. Thats how they made it. Is it stupid? YES it is, but i'm not in a position to change it.
If you like, pull out number 1 plug and rotate the engine until you are on compression, line up your timing marks, then pull the timing cover off and look at the gears. Cam will be at 12 and crank will be at 12, engine is set to install the dist IF you are using the normal cap configuration, IE: number one towards the front of the cap.
Mark
Old 05-17-2004, 07:40 PM
Mark, I belive your right. I turned the engine untill the rotor pointed at #1 that's when I pulled the cover to see the gears at 12:00 and 12:00.
I've got a realy bad feeling about my symptoms, I've got low vacuum and blow-by. I'm thinking maybe somehow I've got some rings in upside down or somehow wrong? I think I'm going to be sick.
Old 05-17-2004, 07:49 PM
Jmark's Avatar
Well, with that cam, you're lucky to have 5 inches of vacuum, at low idle anyway. It should perk up once you get some timing in it.
My sons 400 has the 286 Comp roller and his vacuum sucks too.
Try NOT using the vac advance and set it like this:
Hook up an adjustable timing light and wind it up to 2700 and set the timing to 36 degrees and go for a spin. (56 is WAY too much total timing!)
If the weights are working in the dist, you should end up with around 20 degrees mechanical plus base timing at 14/16 degrees. That cam will need LOTS of inital timing to even idle at all. We ended up setting my sons at 20 base timing and another 14 with the mechanical and NO vacuum advance at all. Seems to be good.
Mark
Old 05-18-2004, 05:57 AM
Last journal entry: PICTURE TEST
dist
I didn't see in your post what kind of distributor your running. If it's a HEI and has never been re-worked the chances are good that it has way to much mechanical advance. With that cam i would not use the vacuume advance at all. Try to get it set at 18 deg intial with 36-38 total. as a base point.
Can you give us some more info... Do you know the static compression or the cylinder psi???? auto or stick, rear gears,
The dots on the chain have many people messed up!!!! It really does not matter iF you assemble the motor with the dots at 6:00/12:00 Or 12:00/12:00 . The cam rotates at 1/2 speed of the crank, so no matter how you align the marks when you rotate the motor 360 degrees they are at the oppisite from where you started. What matters is where the motor is set when you install the distributor. I tell all my customers to remove the valve cover rotate the motor untill you see the # 1 intake open then close continue untill the balancer is at tdc and install the distributor at # 1. When doing this they have never called back with a distributor out 180 deg..... It's a little more work but for the less skilled it works every time.
keith
