confused on my 305 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 03-08-2006, 07:40 PM
confused on my 305
Hey whats up i am the proud owner of an 83 gmc sierra classic 1/2 ton pickup and i just rebuilt the 305 and now i am having problems with the crankshaft not turning. the main caps were not marked and got mixed up but i heard that they are consecutively numbered from front to back is that true.. see the crank is forged steel and has never been turned down and i used standard size bearings. when i torque the mains down i lose all rotation. i put standard size rod bearings on it too but i tightened them down and they all rotate and pump. im so confused. help me please
Old 03-08-2006, 08:15 PM
83sierraclassic,
I want to be sure I am understanding your post before I respond.
Are you saying that you can not turn the engine over as you twist the crank by hand or with a wrench on the front bolt on the crank, so you can install the connecting rods and pistons? Or are you saying that you got the engine running and now for some reason it doesn't crank over any longer, like it is "stuck" in place?
Glad to help just want to be sure I am following your troubles.
Scholman
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
dirt track 305 groomer Engine 12 04-20-2008 02:46 AM
305 head on 350 savman1 Engine 4 10-15-2006 09:18 PM
Silverado Blazer 305 Project william27103 Suspension - Brakes - Steering 1 10-18-2004 04:16 PM
Carb'd 305 to TPI 305, help? coolerow Engine 2 09-23-2003 03:10 PM
