confused pinion angle - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2006, 10:31 AM
The more I read the more confused I get.Maybe old age.I have a 53 F-100.After about 3000 miles it started making a noise like a universal was bad.After checking the rear end I looked at the universal.The 2 shafts that the U bolts hold on the rear were bad.Had grease in them and no needles missing but had grooves in them(shafts).My trans is 5 degrees down and pinion is 5 degrees up.Do you guys think that is a problem? If not I would appreciate your input.Thanks .......Lash
Old 02-05-2006, 10:54 AM
powerrodsmike's Avatar
Wiki Edits: 161
To clarify your 5 degrees down/ 5 degrees up. Are the centerlines of the trans output shaft and the pinion shaft in the rear end parallel or within 2 degrees of each other? If the operating angles are under 3 or 4 degrees the u-joint should have a normal life expectancy.. I would look at the bearing cap on the u-joint to see if it was too tight in the yoke. Or possibly there was the wrong grease or not enough grease. Now if the angles are opposite of each by 10 degrees or your truck is lowered or lifted alot and it puts the u-joint operating angles greater than 5 or 6 degrees max then you have a problem. In any event you should no more than what is specified in the chart on this site here
http://www.drivetrain.com/driveline_angle_problem.html. Hope this helps, mikey
BE different....ACT normal.
Old 02-05-2006, 04:21 PM
Wiki Edits: 49
Here's another thread that explains how to determine correct pinion angle.
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 39 03-29-2015 10:02 PM
Offset rearend and pinion angle murrsue Transmission - Rearend 5 05-19-2007 06:51 PM
Offset pinion and driveline angle? I nned advice. mike bryan Transmission - Rearend 4 10-25-2004 07:37 AM
Pinion Angle Mystery Dep ME Transmission - Rearend 17 08-18-2004 01:02 PM
pinion angle mad55chevy Transmission - Rearend 3 09-09-2003 06:55 PM
