Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Confusion about Alternator wiring diagram
Old 12-27-2003, 08:10 AM
Bigg Redd's Avatar
Bigg Redd Bigg Redd is offline
The question I confused with is I have used a ignition ballast as a resisitor in the charging system instead of a "Idiot" light.
NOTE: "The ignition system is not even connected with this ballast resistor, totally seperate"
NOTE: "The ignition system is not even connected with this ballast resistor, totally seperate issue."
The resisitor is .8 to 1.2 ohms will that work????
Next question should I use an "Amp" gauge or a "Volt" gauge ? Where does that wire into Thanks George
