Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Connect gauges in 53 Chevy pickup with T-350
Old 06-26-2012, 12:57 PM
Mojo56 Mojo56 is offline
Hot Rod Has Been
Find your local speedometer shop and they can make any cable you desire...there are also plenty on-line that can do the same. Most also work on gauges... you will need to have the gas gauge converted to 12 volt and buy a new sending unit.
BTW... you are modifying or hot rodding your truck... if you were restoring it you'd be using all stock components...
