Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Connecting cable TV from the house to the garage
Old 04-23-2011, 05:16 AM
Irelands child's Avatar
Irelands child Irelands child is offline
You can have or make up as long a cable as you need. If you need a longer one, you can buy, or again, make up a longer length. Home Depot and Lowe's both have a section of connectors, splicers, cable, splitters or whatever you might need. WalMart has some as well. You might possibly need a signal amplifier too, especially since you have the older '60s cable in the house. You do not need that fancy crimper to put the ends on if you have an automotive stripper/crimper
