Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - connecting double d steering column to Ranger sterring shaft?
Old 06-08-2011, 12:30 PM
matt167 matt167 is offline
Wiki Edits: 31
I planned on using the Ranger column in my Rat rod which now sits on the Ranger front suspension, but after some measuring, it's just too long and it's the wrong 'style' and I'm not willing to make it work to save a buck.. A Speedway Hotrod column is only $89 and that's what I'll get.. Problem is, I know the shaft is not 3/4" double D. it looks simmilar except it has a bolt thru it for the factory rag joint.. How do I connect the Speedway column to the Ranger steering box? I may swap the steering box for the manual version by the time it's ready for the road, but that shouldn't make a diffrence.
