connecting double d steering column to Ranger sterring shaft? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2011, 11:30 AM
Wiki Edits: 31
I planned on using the Ranger column in my Rat rod which now sits on the Ranger front suspension, but after some measuring, it's just too long and it's the wrong 'style' and I'm not willing to make it work to save a buck.. A Speedway Hotrod column is only $89 and that's what I'll get.. Problem is, I know the shaft is not 3/4" double D. it looks simmilar except it has a bolt thru it for the factory rag joint.. How do I connect the Speedway column to the Ranger steering box? I may swap the steering box for the manual version by the time it's ready for the road, but that shouldn't make a diffrence.
Old 06-13-2011, 07:33 AM
bsa_bob's Avatar
I don't understand the questio, are you asking for help or telling us what you are doing....or are all ready doing, and with out looking and knowing the above hook it up with a borgson u-joint.hth
Old 06-13-2011, 11:18 AM
Wiki Edits: 27
dial caliper time
I've bought the speedway adaptors and they worked fine. sometimes tig welding them, sometimes using the set screws, First tighten the set screw to make a mark then drilling an indent for the set screw to seat, then locktite and double lock nuts on the set screw. Chevy astro vans use a compact DD shaft. and ujoints. I used a couple hooking up the steering on the willys.
Old 06-13-2011, 12:35 PM
Wiki Edits: 31
I don't know what joint/ coupler to get to connect it to the Ranger box. The original column fit in the rag joint and a bolt ran thru it. Looks like a double D shaft but I don't think it is... If I remove the rag joint and use U joints, which I would like to do, do I use 1 of These ?
I think the Ranger box is splined, but it seems the only common spline is 3/4" 36 spline for anything Ford and that is listed for the MII so it may be a custom aftermarket varient as it lists GM also, 5/8" 36 spline is listed for OEM boxes only..I know the Ranger box was also used in Vans and trucks along with a reversed version in Panther cars. But putting in the Speedway column is not a common modification.. Happen to know the spline count for the Ford boxes?
Old 06-13-2011, 01:02 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Borgeson is your ally in doing what you are doing...
Sam
Old 06-13-2011, 01:17 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
Make a plate that will bolt to the rag joint,,, Then weld a double d collar to it, Are a double d shaft to the center of the plate.. Make the collar are shaft about 1.5'' long.. Then you can install a u-joint..
Old 06-14-2011, 12:46 AM
Wiki Edits: 31
Will that still work with the factory extendable shaft? The rag is on the end of a shaft that extends or retracts about 6" and I really don't know what the purpose is
Old 06-14-2011, 06:25 AM
Wiki Edits: 27
steering system
The rag joint is there to act like a metal universal joint and to dampen out vibration. The extendable shaft is there to let the column collaps in a crash to meet covernment specifications in new cars . Both of those things are ignored a lot in hot rods. there are more compact vibration dampers and some companies are now building after market collapsible colums for street rods. Most hot rods do not meet the govt regs for new cars and that is one of the reasons a lot of politicians oppose any modifications to cars even though a lot of things done improve the older modified cars,, disc brakes better suspensions , better handling and enough power to get out of some problems. and they want to scrap older cars.
GM sterring column ID vanislander Suspension - Brakes - Steering 0 09-23-2009 09:37 PM
Steering Column (shaft) collapsed scr8pin_f100 Suspension - Brakes - Steering 8 02-28-2009 11:18 AM
Splined steering shaft for 40 Ford column heyjude076 Suspension - Brakes - Steering 2 12-01-2006 11:31 AM
Sterring Column Rebuild 68novafan Suspension - Brakes - Steering 3 07-27-2006 05:07 PM
steering column shaft moves RodFather Suspension - Brakes - Steering 11 01-13-2005 04:13 PM
