connecting ps pump to t-bird rack/pinion - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2007, 01:33 PM
Re. 85 Thunderbird rack and pinion. Of the two connections, which is the high pressure connect from the ps pump? Its a 3-turn lock to lock R&P if that makes a difference.
Don't have any lines at this point so that's no help.
Thanks
Jerry
Car: 36 Chevrolet 2 dr
Suspension: 84 Corvette C4 front and rear
Steering: 85 T-Bird rack and pinion
PS pump: Type II GM on Alan Grove Bracket w/ remote reservoir
PS Reservoir: Ford Escort
Engine: Lt-1 from 94 Camaro w/ 4L60e transmission
Old 05-06-2007, 04:50 PM
powerrodsmike's Avatar
Wiki Edits: 161
Smaller of the 2 fittings. One has a 9/16" thread size which is high pressure, the 5/8" is for the return to the pump.
http://www.durexpowersteering.com/techtips.html
Later, mikey
BE different....ACT normal.
Old 05-07-2007, 12:41 AM
Thanks
Thank you. I knew someone on this site would know. I ran across the Durex site but never found their tech tips.
Jerry
Starter won't start and fuel pump won't pump after engine reinstall Porschev Electrical 26 02-16-2007 05:43 PM
Crank Pulley Diameter vs. Maximum PS Pump Speed. fiftysix Chevy Engine 4 02-05-2007 07:29 PM
smog pump gone 68_6cyl_camaro Engine 2 04-27-2003 01:37 AM
Lean backfire Camaro76 Engine 5 04-15-2003 06:45 PM
WOT stalling Camaro76 Engine 5 04-13-2003 12:26 PM
