Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Connecting Rod Cap Hitting Cam
Old 08-28-2010, 09:29 PM
abigassbowtie abigassbowtie is offline
Im running a similar combo but with a comp 292 roller and i had the same problem but it was the rod BOLTS that were hitting most likely the same issue you are having i had to tear it back apart and clearance I BELIEVE 1-3-5-7 rod bolts and you need to have .030 clearence and it is a pita to check but should be done
