Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Connecting Rod Cap Hitting Cam
Old 09-01-2010, 09:13 PM
SeniorRodder SeniorRodder is offline
Thanks to all who came to my aid. I was at my wit's end. 409 Bug was right. It was the timing set. I had a CompCams timing chain/gear with the 3-keyway crank sprocket. The 3 keyways where not marked, and I installed it in what I thought was the straight-up position. WRONG. I orderded another gear set from Cloyes (these keyways were marked), installed it today, and now the enging turns just perfectly. What a relief! Thanks again. I really appreciate you sharing your insights to possible fixes.
