Connecting rod gaps - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2010, 03:48 PM
Connecting rod gaps
OK, so I built a 496 4bolt main with an Eagle rotating assembly. In all the books I have read, they call for a gap between the rods and the crank. I have set the gap however, the rods still slideback and forth on the rod journals. Is this ok? Why set a gap between the rods when the gap is not locked in?
Old 10-02-2010, 04:51 PM
kmart0319,
This "gap" is there so the rods do not weld themselves together when the engine is running. As long as you have some clearance you are good to go.
Scholman
retired
5.7" rods or 6" rods for a stroker??? gofastz Engine 67 05-25-2010 07:53 PM
what length connecting rod should I use ernie fields Engine 5 06-17-2007 12:23 AM
connecting rod positions? deathbypontiac Engine 7 05-21-2007 04:38 PM
connecting rod question malibu68 Engine 1 12-19-2006 08:29 PM
Removing Connecting Rod Cap mouseman Engine 3 09-20-2005 04:03 PM
