Connecting rod letters? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2006, 10:11 PM
86 Stang GT's Avatar
POWER BY CARB
I'm rebuilding a 4.3 for my 88 Blazer. The rods have the letters j, k, l, c, e, g. stamped on them. The machinist did not # the pistons at all. Am I to assume these slugs can go in any hole with the notch pointing forward? I'm new to chevy's, please help me.
Old 04-22-2006, 04:55 PM
BOBCRMAN@aol.com's Avatar
MOST Chevy pistons have an off-set pin.. The proper way to install them in older 4.3 is the same as a small block. Piston notch forward. Rod bearing tangs to the outside (pan rail) on that cylinder.
If you install them otherwise you may create a piston knock problem on cold starts.
Junkyard Motors.. Zartan Engine 20 07-08-2011 07:52 AM
Hello Hot Rod Fans acedrummer Introduce Yourself 5 07-17-2006 10:54 PM
2 new forums: Hot Rod Art and Off-Topic Jon Hotrodders' Lounge 2 09-23-2005 03:50 PM
Removing Connecting Rod Cap mouseman Engine 3 09-20-2005 04:03 PM
engine compartment jaxon Hotrodders' Lounge 3 06-04-2004 07:16 AM
